Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 06-05-2006, 08:47 PM
jrod87 jrod87 is offline
high idle in park
MY 90 deville idles high in park then then start to make clanging noise from bottom of engine. please help
Old 06-05-2006, 10:37 PM
caddydaddy caddydaddy is offline
Re: high idle in park
Check the idle speed controller motor.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 06-06-2006, 07:11 PM
the idle speed controller motor was unplugged and it fixed the idle problem but there still is a clanking sound from the bottom of the motor.
Old 06-06-2006, 10:43 PM
OK, so the idle speed motor is bad, that's a common problem as they get older. The clanking, can you describe that more? Is it just at idle, or when driving, etc?
2000 Cadillac STS
Old 06-07-2006, 06:47 PM
it clanks at idle and goes away when you take off. it sounds like its coming from the cat. It clanks in rythm with the engine.
Old 06-08-2006, 11:46 AM
DFBonnett DFBonnett is offline
Try getting underneath and listen while hitting the cat, while cool of course, with the side of your fist or a rubber hammer. You shouldn't hear any rattle or clunking from inside the cat.
Old 06-09-2006, 03:25 AM
D Spec D1's Avatar
D Spec D1 D Spec D1 is offline
Send a message via AIM to D Spec D1
It's probably the main bearing thump problem (harmless) or cold start piston slap (relatively harmless). My car has the latter problem, it sounds like the engine is about to explode for the first five or ten minutes, but if you drive it anywhere (even just down the street), it goes away, right?
The best touge site. Period.
Old 06-09-2006, 06:53 PM
its not that loud its just a iritating clank you can't hear it from the top of the engine just the bottom and it starts when the engine is hot not cold. its weird
Old 06-09-2006, 07:22 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: high idle in park
Bottom line here is, someone who knows what they are doing needs to listen to this noise!
Old 06-21-2006, 04:49 PM
Took the car to a muffler shop, turns out it was the cat, thank you guys for all the help troubleshooting this noise.
