96 SL2 Oil in the Spark Plugs
My Fiance was on her way home today and came to find out that she was low on oil. She said she put a quart in and then came the rest of the way home. When she got there she found that her number 4 spark plug was filled with oil. Any ideas on what might be the problem??? Any help would be appreciated thanks.
1967 mustang coupe new candy apple red paint with charcle striping, 351 windsor rebuilt 100 miles ago, 463 butt gears, B&M QUICK SHIFT, c-4 Transmission, shaved door handles, custom interior - not finished yet, 68 gt wheels-powder coated, slicks for the track, mustang 2 suspension. 1996 Blazer LS 2 door 4wd aftermarket muffler-Flowmaster 40, cold air intake coming, blazer extreme body kit on it's way also, front has been lowered with tensioners, and rear with a block. |
Re: 96 SL2 Oil in the Spark Plugs
I would have to say that its a valve cover gasket, its common on these saturns. Its a real easy fix to do yourself. Pick one up from a parts store with some high temp RTV sealer. Its the hex bolts on the top of the motor there, two in the back, two on the left side, three down the middle and three in the front and it should pull off for ya. Pull the old gasket off lay the gasket down and put a good line of the sealer around the whole thing, then bolt the cover back down. Simple.
Always lookin for sumthin new, hit me up!
Its most likely the valve cover gasket rings around the spark plug tubes. Its fairly easy to replace- but dont put sealer all around on a rubber gasket. Use just a little at junction points. Like where the cam bearing retainers meet the head- put just a little sealer on either side on the retainer.
"The Constitution shall never be construed...to prevent the people of the United States who are peaceable citizens from keeping their own arms." -Samuel Adams, 1786 |
