Old 06-05-2006, 02:48 PM
Liljay2003 Liljay2003 is offline
Connector
What is this under the plactic cover right in front of the 3 plug wire going to the 3 back cylinders< well on or my wire are burnt and just holding by 2 wires treads so what is that connect called, i have a pic or it but i dont know how to put it on here
Old 06-05-2006, 03:35 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Connector
Where is the pic?
Just a guess but are the three wires purple, yellow and pink going to a connector on a bracket? If so that is for the front 02 sensor. Not good news.
Timeslip 08/12/06
AF Community Guidelines
Old 06-05-2006, 05:23 PM
Re: Connector
Here the pic> It crazy how all these problem all at one time< 4 rys 121000 miles and i think it times to go newer but i cant just give up on the prix It my baby, Once everything get in workin order i think im just gone get everything replaced on it< even if nothing is wrong with it< it carried me 1200000 miles< i expect another 120000 well the pic was up there when i was writeing this but it didnt show up on the post i dont know
Old 06-05-2006, 05:35 PM
BNaylor's Avatar
Re: Connector
Still no pic coming up...
Timeslip 08/12/06
Old 06-05-2006, 06:14 PM
Re: Connector
Well i dont know how to put them pic up< but the 1st 02 sensor is in the back of the engine< this connect is in the front or the engine and where the 3 wire comming from the oil pack< the connect is right there in front of those wire< so basicly its right by the coil pack under the cover on the GT grand Prix it like a 10 pin connector < i really didnt count them< but i will>> < on the buttom on the reply box it say insert image and then it says enter the URL or the image< where do i find the URL> i just cut and copy the image and paste it on the page but it didnt show as you see((((())))))It right in front of the front fuel rail over the the coil pack
Old 06-05-2006, 06:29 PM
BNaylor's Avatar
Re: Connector
OK now we are getting someplace. I thought you meant in the back of the engine. If the wiring connector is between the coil pack and alternator that goes to the MAP sensor. If it is the bigger connector close to the right side of the UIM Plenum then that is the joining connector for the coil packs and ignition control module. If it is the connector on the plastic cylinder looking part by the right side of the UIM that is the purge solenoid.
Timeslip 08/12/06
Old 06-05-2006, 06:44 PM
Re: Connector
Can any of those cause the engine to mifire< obviously it comes from the PCm and i have the replaced the whole wire and pin ( the connector < its right behind a plastic piece and has a little tube running into the side of the throttle body
Old 06-05-2006, 06:53 PM
BNaylor's Avatar
Re: Connector
If it is the connector for the Coil Packs/ICM sure. The plastic piece with the vacuum line going back to the throttle body is the purge solenoid. But the purge solenoid does not normally cause a misfire. Just throw a code of maybe P0441.
But it sounds like the connector for Coil Packs/ICM so you may be onto something significant. Good luck!.
Timeslip 08/12/06
Old 06-05-2006, 07:57 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: Connector
How to add an image to your post by blazee: http://www.automotiveforums.com/vbul...d.php?t=531952
Old 06-05-2006, 09:27 PM
Re: Connector
Old 06-06-2006, 07:43 AM
BNaylor's Avatar
Re: Connector
I see the purge solenoid at bottom of the pic and the connector behind it is the joining connector for the Coil Packs/ICM.
Timeslip 08/12/06
Old 06-06-2006, 04:29 PM
Re: Connector
So is there anyway i cant replace that connetor with a new on without taking it to a dealership< i know that go to the pcm well at least the one that is burnt< and those pin i need they sell online< and all the dealership around here dont have them in stock> ( the pins the hook in the the PCM connector But all i really need is that connector< but do they just sell that connector< do you know the part number>
Old 06-06-2006, 07:07 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Connector
I'll check that part number for you when I get to work.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-06-2006, 08:40 PM
Re: Connector
Alright i just need the connector peice i know the part number or the pin the goes into the PCM connector< but thanks
Old 06-08-2006, 08:48 AM
richtazz's Avatar
Re: Connector
If you're referring to the 8 way connector behind the purge valve, the half to the right in the picture is part # PT444 (GM#12117271), and runs $35.59 (dealer retail $71.17). The half to the left, is part# PT443 (GM#12117270) and runs $35.56 (dealer retail $71.11).
