Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 06-05-2006, 11:24 AM
ude_loose's Avatar
ude_loose ude_loose is offline
Send a message via Yahoo to ude_loose
91 626 Reverse Lights
My reverse lights dont seem to be working i have already checked the light bulbs and they are good what else could be causing this problem... My winshield wiper liquid does not work either the one that trows the water on your windshield what could that be... Thankz In Advance....
Old 06-05-2006, 02:48 PM
hocbj23 hocbj23 is offline
Re: 91 626 Reverse Lights
There is a switch on ur tranny that activates the backup lite when u put car in Reverse.Probably needs to be replaced.There is a small pump on the bottom of ur w/s washer fluid bottle.Check to be sure that it is connected . If so, have somebody activate the washers while u stand near the bottle with the hood open. If u cant hear a hum from the pump, it is bad. U can probably find one that works in a junk yard. Also be sure that the washer nozzles are not plugged up.BJ
Old 06-07-2006, 12:07 PM
kevinnate kevinnate is offline
On my 91 626, the wires in the trunk (by the driver-side trunk lid hinge)broken(cut) off, the wires are in-case in a slit type black plastic tube. Good luck.
