Go Back   Automotive Forums Car Chat > Ford > Aspire
Old 06-05-2006, 02:17 AM
shizzledizzle shizzledizzle is offline
My aspire is stuck in reverse! HELP!
I have an manual 95 Aspire. It is stuck in REVERSE and the shifter no longer seems to be connnected to anything and freely bounces around when touched.
One mechanic suggests the connector pin from my shifter has fallen off into the transmission and that I need to replace the transmission.
IS this really the cure for a wabbly shifter and an unresponcive transmission?
HELP!
Old 06-07-2006, 05:26 AM
C. Cleve C. Cleve is offline
Re: My aspire is stuck in reverse! HELP!
Hi, Did you get my Email?????????????? Clay..
Old 06-09-2006, 01:03 AM
TSOPbananaforyou TSOPbananaforyou is offline
Send a message via ICQ to TSOPbananaforyou Send a message via AIM to TSOPbananaforyou Send a message via MSN to TSOPbananaforyou Send a message via Yahoo to TSOPbananaforyou
Yes, the exact same thing happened to me my senior year in H.S. I had a 95 aspire that as I drove it into the parking lot had all gears (so I thought), but when went to park only had Reverse, so I had to back into a parking spot. Luckily enough I had my first hour class off campus so I was the only one around.
Old 04-26-2007, 04:19 PM
docscomputers docscomputers is offline
Well your not alone, Mine did the same thing on the way to work this morning, Bareley even have reverse, I wonder why they suggest getting another tranny, Would it be simpler to replace the pin???
Good Luck?
Old 04-26-2007, 04:51 PM
I would think it's in the labor costs. If you have to find a pin IN the transmission, it would be more labor intensive than just a pull and replace.
Old 04-27-2007, 11:11 PM
eippermx's Avatar
eippermx eippermx is offline
None of yall have said wether your clutch cables were checked out to see if they were actuating the tranny or not.
mark
Love my Pontiacs!
'04 GP GT1
'02 Bonneville
'98 GTP - 2 dr
'98 GTP - 4 dr
'99 GP "Flaming Tomato" GT
Old 05-11-2007, 03:28 PM
It has nothing to do with the clutch realeasing, The Gear shift lever is free floating because the pin that holds it inside the trany has broke or come out.
