Old 06-04-2006, 08:24 PM
sportsb4life7 sportsb4life7 is offline
Send a message via AIM to sportsb4life7
Please Help!!!
well first time in the camaro area.... but there is a car for sale CHEAP less then 500 and it is a 92 RS T-tops V8 Auto... new dash, new flowmaster mufflers, new radiator, most interior is good. transmision good, all glass good. 15" tires\rims new rear tires and more.... Have all ENGINE parts, Has a spun piston barring but everythings still good.
Floors need repaired and some surface rust. Good project car!
Well im not too keen with spun bearings.... how much to get it replaced? what do you recommend i want a summer project.. if this was a Z28 i know it would be alot better but i want your opionions...thanks i have seen a few pics and its not too bad white with some rust by the headlights in the front and some in the wheels area... i need responses quick so thanks
Old 06-04-2006, 08:34 PM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
Re: Please Help!!!
i'd definately get it...even if you dont fix it...you could part it out and make more than $500...if you can stand to part a camaro out.
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 06-04-2006, 08:42 PM
Re: Please Help!!!
It might be bad to say this in here .. i might get shot but i was really into 3000gts and wanted one badly and been in those forums for like 3months but it might be a time to switch over.... i just need to know how much it will cost to fix this engine, i just want to get it running.... i have all summer to work on it.. thanks alot
Old 06-06-2006, 10:03 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Please Help!!!
Cheapest way out is a new short block.
Old 06-06-2006, 04:44 PM
fcdriver fcdriver is offline
Re: Please Help!!!
This would probably be the cheapest way out of it if you can find a good short block.
Last time I rebuilt a 350 it was around $900 for everything needed and that was with boring, having the crank turned and all the bearings, seals, and pistons.
Originally Posted by dampachi
Violence isn't always the answer..but sometimes..depending on the question..it can be the answer.
Old 06-06-2006, 04:49 PM
NRFDBeliever NRFDBeliever is offline
Re: Please Help!!!
engine rebuild kits for a 350 start at about 150 bucks through Northern Auto Parts. You have to pay a bit for some upgrades in the gaskets, etc, but oversize pistons and rings come free. You can use that to try and see if you can fix the existing block, or get another engine with a bad head or something and rebuild it and combine the parts from the 2.
Old 06-06-2006, 10:56 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: Please Help!!!
depends on what condition the block is in. if you pull it out and tear it down yourself, it might not cost you too much. I bought my engine from a junkyard out a 79 truck last year. it had a shitload of miles on it, but it didn't need to be bored (nor honed). i have a pretty good machine shop. had rings replaced, all bearings, freeze plugs, hot tanked, polished crank... and it cost me around 500 dollars. i put it back together myself. check with your machine shop.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 06-07-2006, 09:04 AM
wrightz28's Avatar
Re: Please Help!!!
$900 to rebuild a short block, crankcase only!?!
Did you have the thing gold plated and lined with diamonds?
i don't know why alot people seem to have problems finding motors, between swap meets and boneyards they are a dime a dozen to me to find.
Old 06-07-2006, 11:03 AM
Xbox2202 Xbox2202 is offline
Send a message via ICQ to Xbox2202
Re: Please Help!!!
I was into 3000gts for a while, but I'm glad I bought my Camaro instead. Like everyone else is saying it would be easier to geta a new block. You might as well get a 350 instead of the 305 it has if it's just a summer project. You'll regret having the smaller engine later on if you can find a 350. I know I had regrets for buying the v6 instead of waiting for the v8 when I bought my car. But if this is your first car get the lesser option incase you wreck (it would have been a shame for me to total a z28 if I had bought it as my first car instead of the 6).
1994 Camaro V6 A4 - RIP 3/1/06
http://www.cardomain.com/memberpage/805164
1994 Camaro Z28 A4 - Bought 4/6/06
Old 07-24-2006, 05:30 PM
Mr Common Man's Avatar
Mr Common Man Mr Common Man is offline
Re: Please Help!!!
I agree it would be a great deal, getting a engine is nothing. I've been looking for a SS 90-00 myself, no matter what kind of condition the rest of the car is I just want the engine.
Old 07-24-2006, 05:52 PM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
Re: Please Help!!!
The SS didn't come back until '96. The 96's and 97's had LT1's whereas the 98-02's had LS1's.
