Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-04-2006, 07:45 PM
riverrojo riverrojo is offline
Overheating (customer car)
Not used to working on DSM's, so I thought you could all lend me a hand. I have a customer who brought in his Gen 1 eagle talon AWD turbo in for overheating. Pressure built up and blew the upper hose radiator neck off. Installed a new radiator and it still overheats. Took out the thermostat, still overheats. I realized that the fans were not turning on. They do turn on when the ac is on. Temp gauge on the dash is working.
Any ideas? Thank you for your assistance.
Old 06-04-2006, 07:56 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Overheating (customer car)
your main fan is not working properly. 1 fan turns on with the AC, iirc, it is the passsenger side fan. If the other fan doesn't turn on at all, I believe it should turn on at 210 degrees, then either replace the fan, the wiring, or the switch it connects to
now - 2000 civic
soon - 2002 is300
Old 06-04-2006, 08:44 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Blown head gasket
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 06-04-2006, 11:57 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
If neither of the fans work (like crunchy said they only come on at higher temps) that would be it if the car starts to get hot get out and check if the fans are on. A cheap fix is to bypass the thermo switch and have the fans run all the time.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 06-05-2006, 12:01 AM
blk_srt's Avatar
Does the car still blow the radiator hoses? Does it blow cool or warm air out of the heater?
Mods:
Originally Posted by pr_ricer
Blown head gasket
Check the fans first. No fans = automatic overheating = boiling = pressure
now - 2000 civic
soon - 2002 is300
Old 06-05-2006, 01:23 AM
I turn the car off before it has the opportunity to blow the hoses. Car blows hot air, so there aren't any air pockets in the heater core. Both fans turn on with the ac on. Neither are activated when car is overheating.
Old 06-05-2006, 05:47 AM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Does it still overheat when you keep the ac on?
Also have you checked to make sure the fluid is circulating?( I know you said it blows WARM air but just a thought thats all)? Is both upper and lower hoses hot or have pressure on them?
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 06-05-2006, 10:32 AM
blk_srt's Avatar
so the car builds up alot of pressure fast?
Mods:
Old 06-05-2006, 01:29 PM
The coolant is circulating, we can see it moving in thee reservoir. The car doesn't build up pressure too fast. Takes about 15 minutes to come to the middle of the temp guage. Heat blows hot. Switched the foglight and the fan relays to check if the relay could be bad. Fans still not turning on automatically. I ran the car until the temp gauge hit the red. The fans will turn on when ac is acvtivated.
Thanks again for all of your help.
Old 06-05-2006, 02:08 PM
Black97GST Black97GST is offline
im assuming you checked the obvious things first...... coolant, what shape the oil is in (hopefully not like chocolate milk).
Old 06-05-2006, 02:38 PM
Oil is nice and fresh.
Old 06-05-2006, 03:45 PM
blk_srt's Avatar
have you verified its overheating and not just a faulty gauge and or sender/sensor?
Mods:
Old 06-08-2006, 07:23 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Okay, the driver side fan turns on when I turn on the AC and the passenger side fan turns on when my car runs towards hot. Thought I would add my two cents.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 06-09-2006, 01:02 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
The coolant shouldn't be moving the resirvor, all that is is an overflow tank and the coolant shouldn't technically be "moving" around at all. I'd fill the car up with coolant (the radiator, not overflow resirvoir) and then check the thermostat and temp gauge sender. If all those check out good then you're into much bigger problems.
95 Talon TSI AWD
97 Eclipse GST
