Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 06-04-2006, 06:50 PM
sonnyboy1105 sonnyboy1105 is offline
no spark 1995 t/c
My 1995 towncar will not start. It is getting fuel but no spark. I checked the fuses in the fuse panel under hood and fuse panel under drivers side dash. Is there other fuses or relays to check? Any suggestions on what it might be if not a fuse? Thank you for any help.
Old 06-04-2006, 10:19 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Re: no spark 1995 t/c
Are you geting spark to any cylinders? could be a bad coil pack. I would look at th ignition module first, its mountd on the drivers side fender well area on the 93's I have. I don't know off hand itf it will interchange with your model. I think I might still have some of those modules left for the 93 TC. in our e bay store. There is a link to the store at our website cmasalvage.com
Thanks Mike
Old 06-05-2006, 04:21 AM
sreilly77's Avatar
sreilly77 sreilly77 is offline
one or both of your coil packs could be bad. but about 3 weeks ago i had the same problems with my 95 town car. i had no spark. turned out to be the crankshaft position sensor, which is located behind the air condition compressor. but it could also be the camshaft position sensor.
Sean
