Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 06-04-2006, 04:27 PM
bear959 bear959 is offline
Starting issue
I have a 2000 jeep wrangler that I have a hard time sarting sometimes. It seems that the longer the car sits, the harder it is to start. The dealership went through the jeep and changed the spark plugs. I thought it was a fuel filter or fuel pump but they say no.
Any thoughts?
John
Old 06-05-2006, 08:07 AM
tomvid tomvid is offline
Re: Starting issue
Is the check engine light on?
I had the same problem and it was the crankshaft position sensor. Althought the check engine light was on and it gave me the error code for it.
Search this forum for crankshaft position senor. There are alot of threads on it.
Old 06-05-2006, 01:57 PM
Re: Starting issue
The check engine light has never come on.
Old 06-05-2006, 02:14 PM
Re: Starting issue
What exactly do you mean by hard start?
One or two cranks, or one or two consecutive series of cranks?
How does it run once it is started?
Old 06-05-2006, 04:44 PM
Re: Starting issue
The longer the jeep sits,the more you have to crank it. Once it starts, it runs great. I can shut off the jeep after starting it and I can restart it with no problem.
Old 10-10-2006, 04:04 PM
mose32 mose32 is offline
Re: Starting issue
I have a 97 Wrangler with a 4 cylinder engine with the same problem - cranks a while to start it and then it runs fine. I just did a tuneup with new plugs, wires, distributor cap, and rotor - had the problem before and still have the problem. I was going to check fuel pressure. I think I'm supposed to see 40psi with key on and engine not running...? Any other suggestions?
Old 10-11-2006, 02:24 PM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: Starting issue
I could be wrong(it's happened before :} ) but to me, it sounds like the problem is in the fuel system. to check things out, put a fuel preasure guage on the fuel rail. (preferably after it has sat a wile(when it would normally take a wile to start.) then, turn the key on, and watch the guage. if it takes a wile for the preasure to come up, then I'd check the filter/pump assembly(sorry, but they are both in the tank.)
if the preasure comes up quickly, turn the key back to the off position. continue to watch the guage to see how fast the preasure drops. if it drops really quick, there is something letting the preasure off; either a bad check valve(I think that's in the pump also) or posibly a leaky injector.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 10-11-2006, 02:45 PM
Re: Starting issue
I'll put the fuel gauge on it this weekend.
Should I order some replacement O-rings for the injectors and plan on pulling them out also for a cleaning? If so, what's the best way to clean them? Any advice on this?
Old 10-16-2006, 11:45 PM
4x4grey88's Avatar
4x4grey88 4x4grey88 is offline
Re: Fuel injectors
Try putting some acetone in the (full) gas tank. it will clean those fuel injector quite well without having to remove them. It cleans the intake system at the same time. You should see an increase in proformance too. About one quart per 15 gallons of gas. This works on fuel injection as well as carbs.
Give it a try, it's cheaper manually cleaning.
Happy Jeepin
www.jeepforum.com; www.socalultimate4x4.com
1998 Wrangler (replaced my 88 XJ)
21' Mini Winnie (replaced my Pace Arrow)
