Old 06-04-2006, 03:11 PM
[email protected] rwolak@verizon.net is offline
Wheel hub sensors
I have the problem with the ABS/Traction control lights being on and the ABS pulsing. I did some investigating on this forum about the wheel hub sensors and found that they should read between 950 - 1250 ohms resistance. 3 of the 4 sensors read between 1150 - 1200 ohms. The 4th. reads 1975 ohms resistance. Can I safely assume the 1975 ohm sensor is the bad one????
TIA
Bob
Old 06-04-2006, 06:11 PM
vamc's Avatar
vamc vamc is offline
Re: Wheel hub sensors
I would replace the sencer and then take a reading.
Old 06-05-2006, 07:31 AM
Amazingly, when I took each of the connectors apart and measured the resistance, I sprayed each with electrical contact cleaner before putting them back together. The ABS/Traction control lights haven't come back on since then. Maybe that's what the problem was---either some moisture or poor contact. Guess time will tell!!!!
