steering is out
my 2000 jimmy has had all ball joints replaced and the pinions aswell however when driving on the hwy i must hold my steering wheel slightly to the left as if my alignment was out however it has been done twice so it is not the alignment. it feels as if the steering wheel is a bit loose / has play to the left when driving , can anyone help this matter ?. thx.
2000 GMC Jimmy Diamond Editon ( Black ) 1991 Dodge Shadow ES Turbo 242WHP 365WTRQ Best so far [email protected] MPH Capable of WAY more. |
Re: steering is out
All of the steering linkage should be checked for wear: Idler arm, pitman arm, tie rod ends and center link. Suspension parts should also be checked: Upper and lower control arm bushings, stabilizer bar bushings, end link bushings, and the shocks. The "rag joint" coupler at the steering gear, or wear in the steering gear itself, may also be causing the play. Adjusting the preload in the steering gear may take care of it, if not, the gear will need replacement.
The drift or pull to the right while driving might be caused by the right brake dragging. Make sure that is not the case. Alignment angles incorrectly adjusted could also cause a drift or pull. Tires can also induce a drift or pull. Every tire has a certain degree of conisity, (shaped like a cone) and will not roll perfectly true. Try switching the front tires side to side and see if that helps, if not, it's an alignment issue. |
Re: steering is out
sorry it was my pitman arms that were changed not the pinions..
