Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 06-04-2006, 10:42 AM
olejude olejude is offline
Thumbs down not getting enoug gas?
I have 1993 Grand Marquis LS. From 0 to 30 on slight up hill incline chugs like not getting enough gas. Last Sunday it would start idle real rough and die did this about 12 time before starting. Tried reving it and it would die. Check engine light comes on fast when over drive is off. When is on doesn't come on for a while. Questtion is this a clogged fuel filter? Oxgyen sensor or do I need a new fuel pump?help!
Old 06-05-2006, 07:18 PM
Re: not getting enoug gas?
well the answer to that was new fuel pump, gas filter, and ignition $522.24 is the problem fixed? will let you know tomorrow.
Old 06-05-2006, 09:19 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
are you doing the work your self or a shop? if so stop and start with the fuel filter and also have you cleaned ur mass air flow sensor lately
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 06-06-2006, 09:51 PM
had car in shop Mon they replaced fuel pump, filter and ignition switch. Drove it to work today it is sti;; chugging going up hill 25 to 45 mile an hour acts like it is not getting enough gas. help this is getting expensive
Old 06-08-2006, 01:07 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Air filter. Plugs, cap, and rotor. And like Cobradude said, try cleaning the Mass Air Flow sensor, and also the inside of the intake.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 06-08-2006, 10:25 PM
miamibob's Avatar
miamibob miamibob is offline
Sorry but a '93 does NOT have a "cap and rotor". It has Coil Packs where the Ignition Wires (Spark Plug Wires) attach directly. Speaking of which my first move would have been to change the Spark Plug Wires. Did you do that and perhaps I missed it?? Use HIGH QUALITY wires ONLY (like AUTOLITE) and also don't forget to put some Dielectric Compound in BOTH ends of the wires before attaching. MB
Old 06-09-2006, 09:11 AM
My bad, I forgot the 4.6 came out in 93....I was thinking 5.0.
Old 06-10-2006, 03:56 AM
KimMG KimMG is offline
AF - Advisor
Does it make a difference if the fuel cap is off? A clogged tank vent line can restrict the flow of fuel.
