Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 06-04-2006, 08:34 AM
jj76ta jj76ta is offline
2003 push button entry code reset
My wife just purchaced a 2003 mountiner this week. It didn't come with a owners manual. We would like to know how to set the code for the push button pad on the drivers door. Any info would be appriciated.
Old 06-04-2006, 11:53 AM
Re: 2003 push button entry code reset
solved the problem. Well the code for the entry pad for my 2003 Mountnier is on the ecm. The ecm is located behind the rear door on the passenge side. Remove the panel on the inside and you will see it. The panel is just clipped on and no tools are needed. The code is on the White label on the ecm. It is 5 or 6 digets and they are written large off to one side of the lable. After you enter the code it will unlock the drivers door. then push the 3 and it will unlock all doors, then if you want push 5 and the rear glass will unlock. probly some other fetures that it does if you can figure them out. Good Luck.
