Fuel injector leakage on 2.2L 5S-FE
If an injector is clogged, will it cause it to leak? Or would it just not fire on that cylinder? Cuz I just found one leaking, pretty badly. Or is it maybe just the O-ring leaking? It runs fine, but just had a strong fuel smell, and I finally found out why
Guess Im gonna hafta yank the intake off either way. Thanks for any help!
Re: Fuel injector leakage on 2.2L 5S-FE
If its leaking to the atmosphere, it may be just the seal O-ring you have to change. And the injector itself may be ok.
Leaking at the seal doesn't necessarily indicate injector leakage. "Injector leakage" is another way of saying the spray pattern is incorrect and the injectors are dribbling fuel instead of spraying it. And this does indicate the injectors need to be to be cleaned or replaced. |
It was just the O-ring, Marc, so I replaced all the gaskets on all four of em and it worked like a charm. Thank you for your help
Bumping this up.
I have exactly the same problem, but please tell me I don't have to yank the intake out cause judging by the looks of it, it looked to me like it could be a 30 minute job... |
