Old 06-03-2006, 09:42 PM
globingene globingene is offline
HELP --- air conditioning doesn't work
When I turn on the A/C switch, clutch doesn't engage. I check low end pressure, it is OK. Is it could be electrical problems or compressor?
Old 06-03-2006, 10:13 PM
pjshaker pjshaker is offline
Re: HELP --- air conditioning doesn't work
you might want to start by seeing if it is out of the freon...or whatever it takes...you can find out what it takes at an auto parts place....
if not that....you might need a new compressor.....my girl just had to replace hers...the fluid was full but a/c was not working...it ended up being the compressor
Old 06-05-2006, 01:08 AM
PotIsYourFriend PotIsYourFriend is offline
Did you check the fuse for the compressor? It's located under the hood...
P.S. Welcome to the "Roll Your Windows Down for A/C Club".. Great timing for the a/c to go out, eh...
Old 06-05-2006, 07:54 PM
lowellw lowellw is offline
Is the fuse you mention the same thing as the Air Conditioning Compressor Mico Relay?
Also what is meant by "low side" or "low port" for recharging the syster? Where is it and where is it located?
Old 06-06-2006, 03:59 PM
Nope.. It's Number 37 (Air Conditioning Compressor)
