Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 06-03-2006, 08:38 PM
Ron21 Ron21 is offline
Question 1997 Aerostar Brake and signal Lights not working
I am having a problem with my 19997 Aerostar. The Brake lights do not come on when the brake pedal is depressed. However the light in the middle at the back comes on. I have check the fuse which is ok. Also when the left or right turn signal are used, the lights do not light up on the front or back nor do the emergency flashers work. I don't know if this is connected to the brake light problem.
Any help would be appreciated as I am lost.
Old 06-05-2006, 12:42 AM
KimMG KimMG is offline
AF - Advisor
Re: 1997 Aerostar Brake and signal Lights not working
Did you check the bulbs? Did you check to see if power is getting to the sockets? Do you have a wiring diagram?
Old 06-05-2006, 06:37 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
If the bulbs are good, check the multi-function/turn signal switch. The affected lights run through this switch.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-05-2006, 08:33 PM
2aerostars 2aerostars is offline
I have a 97 also. I had a similiar problem. I found the spare tire mounted under the van had worn a wire bare and caused a problem with the turn signal not working when the bulbs were ok, and also it seems like the same thing happened with the flashers. -Jim
Old 12-18-2006, 11:39 AM
happyjj happyjj is offline
Did you ever find the problem? I have a 94 and it doing the same thing. I have checked for borken wires, ck the fuse and bulbs all seem to be ok. Please HELP
Old 01-30-2007, 09:27 PM
Yes I found the problem... Turned out to be the multi fuction switch under the steering wheel. Changed that no more problem
