Old 06-03-2006, 05:13 PM
scott6497 scott6497 is offline
Angry grinding sound - front end!!!
2000 gpgt making ginding sound and vibrations that can be felt through the steering wheel, front seats, and gas pedal. I have repalced the front and rear wheel bearings (AC Delco), as well front rotors and pads. The sound is loudest between 20 and 30 km/h. Above 30km.h the sound is like a bad belt in tire. The problem occurs when drivng straight or turning (i.e, changing lanes on highway). It has been suggested possible transmission related problem? Any help would be appreciated.
Old 06-03-2006, 11:56 PM
BlueGT02's Avatar
BlueGT02 BlueGT02 is offline
Re: grinding sound - front end!!!
you said it sound like a belt in the tire shifted, did you change the tires?
I once heard some one have this proiblem on a different vehicle and it was a problem with the upper strut plates missing all the rubber and grinding.
Heres a list of the other things you may want to invetigate.
look for posible failed engine/trans mounts.
look at cv boots for leaking
check tierod ends for play
also check the lower control arm bushings.
Im sure i missed a few but some of the more knowledgeable members will chime in and fill in the blanks
goodluck
The Three Steps to Automotive Repair:
Step One: Find The Problem
Step Two: Fix The Problem
Step Three: Hide The "Extra " Parts
