Old 06-03-2006, 02:48 PM
shab_xp shab_xp is offline
What's wrong with the engine?
I have a 96 Camaro RS, V6 3.8 Liter, auto.
The engine is making some slight ticking, kicking noise when the load is low, i.e., the noise is there when I'm driving at a low speed, or the transmission just shifted to a new gear; but the noise is gone, when I'm accelerating heavily (before shifting) or driving fast.
I bring it to TirePlus. They do not know what's wrong. They recommend me to the dealer. But dealership is always too expensive for me.
Thank you for your reply.
Old 06-03-2006, 02:58 PM
goldz28's Avatar
goldz28 goldz28 is offline
Re: What's wrong with the engine?
Might be a U joint.
Good luck man and welcome to the forum.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 06-03-2006, 03:02 PM
Thank you Secretary .
Could you give me more information about the U joint? I'm not familiar with U joint.
Originally Posted by goldz28
Might be a U joint.
Old 06-03-2006, 03:10 PM
goldz28's Avatar
I had the same thing on a 96 chev pu. I am not very mechanically incline but with low rpms that would allow for more slack in the drive line that would cause you kicking or clicking noise. when you get on it would tighten up the slack... But I am not even sure if thats it, so if you can give some better details on what is going on someone will be able to help...
Edit- might be called constant velocity joints also...
Old 06-03-2006, 03:16 PM
maxwedge maxwedge is offline
A990 racer
Exclamation Re: What's wrong with the engine?
Tire Plus? Find a qualified indepedent mech,. have him drive the car, show him the noise, I am sure he will know what it is, no one here can accurately determine the source of a drivetrain noise without on site analysis.
Old 06-04-2006, 07:31 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
werd...
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 06-04-2006, 11:25 AM
I just came back from Pepboys. They said it might be a Catalytic Converter problem. But they do not repair that.
Thanks for your reply. I will keep you updated.
Have a nice day!
Old 06-04-2006, 03:56 PM
goldz28's Avatar
Why did they say it might be a catalytic converter? Does it smell like eggs?
Old 06-04-2006, 04:45 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
They are commonly refered to as CV joints for short.
That dosen't sound like a cat problem to me, they might be just trying to get you to pay the big money to get it replaced.
Old 06-04-2006, 09:28 PM
goldz28's Avatar
It sounds like a U joint to me, but whatever I am no mechanic or even pretend to be... I would be happy if I am right tho...lol
Old 06-11-2006, 10:33 AM
Hi guys,
I have finally fixed the problem. The noise is diagnosed from Transmission by Exhaust Center. AThen it took the mechanic a lot of time to find out that it's actually from the starter, which is located right next to the transmission. After I have the starter changed, the noise is gone forever.
Thanks for your replies. It's always good to have some advice from here.
Old 06-11-2006, 11:08 AM
loose starter motor....yeah that would make some noise...
