Old 06-03-2006, 02:39 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Radiator Fans Not Working
Those are supposed to turn on when I turn the car on right? Well they're not moving an inch and it's bothering me.
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 06-03-2006, 04:01 PM
stepho stepho is offline
Send a message via AIM to stepho Send a message via Yahoo to stepho
Re: Radiator Fans Not Working
I think they only turn on when the car gets to hot.
I'm not sure though...
Originally Posted by sportlinetta
lol, u guys are dummmmmmmmmmmmb im 14 n i know more. i gotta 88 camaro.
would that mean get a new cylinder or plug???
Old 06-03-2006, 04:17 PM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
i think theyre automatic fans that turn on like at two hundred and something degrees.
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Old 06-03-2006, 04:52 PM
Dyno247365's Avatar
That's a relief, so I can't really check them now until I've got a steady idle.
Old 06-03-2006, 10:04 PM
pjshaker pjshaker is offline
depending on the thermostat you have in they will turn on at either 160 or 190 degrees.....
190 is stock...keep an eye on your temperture guage....if it hits 200 and is rising check the fans......if you shut the car off and it is that hot the fans should still run till it gets to the right temp.....
if you have the 2 fan setup and both fans are not working you might want the check your fuse or relay....usually both of the motors will not die at the same time....
if you have 1 fan and its not working...then start with the small stuff first...check the fuse under the hood first....and the then see if the motor is done....
Old 06-04-2006, 07:03 AM
skyluslondon's Avatar
skyluslondon skyluslondon is offline
check after your temp gets to about 220, or its normal peak temp. my primary fan is supposed to turn on at 220, then turn off at...whatever. also, if you want to check if your a/c fan is working(normally the passanger side fan i think) you can just turn you a/c on and if its not spinning than its clear you have a problem.
Old 06-06-2006, 09:51 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Normal op. temp is 220
The stat has nothing to with what temp the fan comes on.
On a 3rd gen they come on 230-235ish and off at 210-205 +/-.
Old 06-06-2006, 10:21 AM
Dyno247365's Avatar
But my temperature gauge doesn't work, I told you in another thread *laughs to himself*
Old 06-06-2006, 10:34 AM
wrightz28's Avatar
Too many damn threads to keep track of with this car and I'm 4 days behind.
Old 06-06-2006, 11:00 AM
Dyno247365's Avatar
I'm so close to finishing it, I truly am damnit! It's been such a long year and I'm this close!
Old 06-06-2006, 12:25 PM
git-r-dun..it'll be worth it.
