Old 06-03-2006, 02:05 PM
donnap1957 donnap1957 is offline
96 GA 2.4L - Help Replacing Serpentine Belt
I got it off, and the new one is routed except around the tensioner. Am I suppose to be able to get it on by releasing the tensioner? I have but still can't get it on.
Old 06-03-2006, 02:20 PM
showstopper_88220's Avatar
showstopper_88220 showstopper_88220 is offline
Send a message via Yahoo to showstopper_88220
Re: 96 GA 2.4L - Help Replacing Serpentine Belt
Yeah these are a pain in the butt to put on. how I usually do mine is to have someone else hold the belt on the crank pulley while I route the belt around the alternator and the a/c compressor. You have to hold the tensioner as far back as it will go to let the belt slide on it. Once you get the belt on it release the tensioner.
Showstopper_88220
Old 06-03-2006, 06:48 PM
You don't undue the motor mount bolts?
Old 06-04-2006, 01:37 AM
vtjvt vtjvt is offline
no need to undue the motor mount bolts, I usually route mine around the tensioner and the once I release the tensioner I put it around the altenator, takes all,of 5 minutes once you get the hang of it.
My car is also a 96 gase with a 2.4
Old 06-05-2006, 10:10 AM
Thank you all for your help. There are a couple secrets that do make this easier. Releasing the top 3 bolts on the motor mount does provide a little extra room but the advice that did the trick is using a cheater wrench. That is the only way to get the room you need to crank the tensioner.
