Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 06-03-2006, 01:40 PM
MrCoffee35 MrCoffee35 is offline
96 LHS stuck in limp mode
I have a 96 LHS, the car is not stuck in limp mode ( 2nd gear )
I tried a ODBII scanner from the dealer and we where not able to communicate with the computer and it shows 55 if we turn the key 3 time.
So I started to check all the wires one by one for any broken wires and found notting..... I got my self a OBDII scanner and tried again and voila I got this error that pop out that the TCM ( Tranny computer is not reponding ) I look and oups I forgot to connect back the module, after putting back the computer I reconnect the battery and again not able to communicate with the computer again
Looks like there is someting that is shorting the communication bus or there is someting open somewhere any idea what would cause this problem ??????
Old 06-03-2006, 03:55 PM
Re: 96 LHS stuck in limp mode
found one problem, there was a 12 volt missing in the transmission control relay pin 30, now the tranny works fine but I still have this communication problem with the ODBII scanner.
If I remove the tcm I am able to talk and get codes in the PCM.
Old 06-12-2006, 05:33 AM
Ben M Ben M is offline
I had the EXACT problem....95 LHS.....limp mode at 40 mph. Dealer replaced the trans module and solenoid..part numbers....4539766....solenoid 080590 and the module...R4797708AA module 08035028.
Damage...$620.32 including labor.
Old 11-21-2006, 08:02 PM
shorty21becky shorty21becky is offline
Angry Re: 96 LHS stuck in limp mode
[quote=MrCoffee35]I have the same problem with my 94 new trans,t.c.m, still not working i can communicate thru a modis scanner and tells me 2-4 selenoid error where did you fin that wire
Old 11-22-2006, 07:02 PM
twistedtech twistedtech is offline
[quote=shorty21becky]
Should have started your own thread but we are here now,first thing I would be doing is hard wiring the two plugs by the right strut tower that run down to the trans.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
