Old 06-03-2006, 06:54 AM
corey1127 corey1127 is offline
Unhappy 1994 Buick Park Ave
I have a 94 Park Ave and when driving the motor shakes bad and when you try to get it gas the motor shakes and doesn't pick up speed fast I've changed the fuel filter, plugs, wires, crack & cam sensor added lucas fuel cleaner and dry gas and sometimes it shakes, and sometimes it take awhile to shake. Very slow pick up speed. Please help.
Old 06-03-2006, 07:42 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: 1994 Buick Park Ave
Have you checked it for trouble codes? Also, when you say the motor shakes, it sounds to me like bad motor mounts?
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 06-03-2006, 10:01 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Sounds like a coil pack issue. Are you getting spark on all coils? You did get non-Bosch plugs, right???
I don't think bad motor mounts would affect slow acceleration so I would suggest that you also check for a vacuum leak. Another possibility would be a clogged catalytic converter. Put your hand under your tailpip and see how much exhaust is coming out...if you cant feel much air or just a puff once in a while then that would be your problem (probably).
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 06-04-2006, 08:11 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
In addition to the above suggestions, you could be near the end of the service life of your timing set, or have the infamous cam gear interrupter, (magnet) issue. Loss of power in addition to "motor shaking" is a key indication of timing problems. How many miles are on this car?
