Old 06-03-2006, 03:45 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
a few more things for the B
ok i did the mpfi swap to ot and i traded my turbo for the rest of the swap at my local shop. i now have everything i need execpt 2 things that are easy to come by. so what i wanted to know was what should i di to check or fix my code 10 on the ecu. and i still ave the same problem with my fuel pump. it is not getting any poer after the mpfi swap. i checked the pump it works when givin power. just not at the begining when you first turn the car to accesories. and not after either. im pretty sure it the power going to it. i just need to knopw which is which so i can rewireit myself. thanks
Old 06-03-2006, 07:53 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: a few more things for the B
For my code ten, I just ran new wires from the sensor to the ecu, but beware..c12 is not only used by the IAT, when I soldered it straight ot it, I mysteriously got a coolant temp code...damn, so to remedy this I spliced the new wire into the original wire..so basically I just jumped into the old line right at the ecu, and away went my coolant code. My baby runs smooth as can be now, that is of course until I get on it..which is when I throw a 23 (knock sensor), this is because I broke the bloody thing trying to unplug it..it just seperated right in two, so I need to thieve one from the junkyard..
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
