Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-02-2006, 10:03 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
popping noise
for a while now I hear a popping noise from my Rodeo. The best way to describe it is like a stone hitting the car on metal. It usually occurs while going straight. I tried shaking the car, but that doesn't replicate it. It happens every time I'm in it, every so often. It seems to be comming from underneeth and maybe in the middle of the vehicle.
any ideas?
marc
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 06-02-2006, 10:19 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: popping noise
It could be the sway bar hitting the shock.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 06-02-2006, 10:26 PM
Tom01Rodeo Tom01Rodeo is offline
Re: popping noise
Mine has the same type of thing. I notice it most when driving into the wind. Sounds more like sheetmetal loose.
Old 06-03-2006, 09:21 AM
themkl themkl is offline
Re: popping noise
Mine makes a popping noise also, believe it to be the hood as it vibrates in tune with the popping
Old 06-21-2006, 06:30 PM
marcre's Avatar
Re: popping noise
hmmmmm, I just realized today that I heve a lot of stones in my tire tread. Due to the fact my cheap landlord has part of the parking area done with stone. The noise I hear verywell may be stones getting kicked up onto the underside of the Rodeo. Hopefully that's it.
My Rodeo
Old 08-02-2006, 07:36 PM
brayburks brayburks is offline
Re: popping noise
I have a 99 amigo 3.2 v-6. The popping sound(sounds more like a loud "clack" noise happens intermittently and can be heard better with the passenger window open at around 30 mph, and alot better when you are driving next to something that seems to reflect the noise back at you(like driving on the road through a wooded area, or through town where the buildings are close to the road).
I don't think it is caused by stones in the tires flying loose and hitting the inner fenderwells. It sounds more like metal on metal. I'm wondering if this is the beginning of a problem with the tranny, or maybe it is something in the engine. It sounds like it is coming from the passenger side in the engine compartment or from under the vehicle in the left front. It has been doing it for several months now, but I don't put too many miles on the vehicle. Any help would be appreciated.
Old 08-02-2006, 07:46 PM
marcre's Avatar
Re: popping noise
Forgot about this thread. I moved a less than a month ago, haven't heard the noise in a while either.
My Rodeo
Old 08-02-2006, 07:54 PM
Ramblin Fever Ramblin Fever is offline
Re: popping noise
brayburks - with your truck idling, stick your head in the passanger front wheel-well and see if you can hear the clacking.
If so, could be time for an oil change and/or timing belt tensioner could be getting weak. How many miles are on the truck?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 08-06-2006, 06:11 PM
Re: popping noise
I only have about 56k on the amigo. I change the oil regularly, so it can't be that. I was thinking it might be the timing belt tensioner, but the mileage seems low for that sort of problem. It sounds to me like an alloy metal to metal. It doesn't have a ringing type sound to it. It almost sounds like the AC compressor kicking on, but the AC isn't on and I don't feel a load on the engine when it happens. Could it possibly be the fan clutch? I'm a bit concerned b/c it seems that is is happening about once per minute and doesn't seem to have any type of pattern to it. Hopefully it is not a breakdown waiting to happen.
