Old 06-02-2006, 08:23 PM
SsHaDyGt SsHaDyGt is offline
Which actutator controls left/right vents?
My 98 GTP is blowing hot air on the drivers side when the AC is on. The passenger blows cold. I DO NOT have the dual zone. I found three accutators in the dash. is there an accutator or door that controls what comes out of the left/right of the dash on a non-dualzone? If not then are there any other suggestions? I dont think my AC needs a recharge becauses its blowing ice cold on the passenger side. BTW my dash is all ripped apart.
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Old 06-02-2006, 08:47 PM
Re: Which actutator controls left/right vents?
I read something that an outside air vent could be stuck open. Is there a seperate outside air vent for each side?
Old 06-03-2006, 10:38 AM
BNaylor's Avatar
BNaylor BNaylor is offline
All HVAC air intake comes in from the passenger side cowl and air inlet. The flapper you are referring to opens when the AC is in the normal or vent positions on the climate control. It is supposed to close when the AC is in the MAX/Recirculate position. I don't believe that is your problem.
Although the passenger side is cool have you checked the low pressure charge just to be sure? A low refrigerant charge can cause the uneven cooling across the evaporator core and felt at the vents.
If charge is OK, then you may have a vent channel problem in the lower part of the HVAC assembly which is allowing hot air from the heater core to mix with the cold air from the AC evaporator. The part that controls this is called a temperature actuator which will move depending in the temperature setting.
Timeslip 08/12/06
AF Community Guidelines
Old 06-12-2006, 11:42 PM
DJ JEFF DJ JEFF is offline
Did you get this fixed??? I have been waiting to see what you did. Mine is doing the same thing. Very frustrating problem.
