Old 06-02-2006, 07:45 PM
scott07422 scott07422 is offline
coolant temp sensor
Can the temp sensor be bad i have a 91 Chevrolet Camaro Convertible my goes all the way in the red but i dont over heat When it get hot it is a little sporadic and when i pop the hood i would expect it to be super hot, but it not...
let me no thanks [email protected]
ps i cant see or feel the sensor is it hard to put a new one on the top of the dash
Old 06-02-2006, 09:19 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: coolant temp sensor
k....the coolant temp sensor for the computer should be on the upper front of the motor. The coolant temp sending unit for the guage on your dash is on the drivers side head. You might want to make sure that your fans are coming on to begin with. The fan switch is on the passenger side head. Could be bad...could be that the connector is loose. Mine was.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 06-02-2006, 09:20 PM
btw....spell check....its a good thing....
