Go Back   Automotive Forums Car Chat > Honda > Integra
Old 06-02-2006, 07:28 PM
hungarian_boss hungarian_boss is offline
Send a message via AIM to hungarian_boss
Semi-Oscillating RPM
My problem is just as it reads. My problem is when my engine is idling or I'm neutral my RPM's tend to go down then return to normal, they never increase. But this happens everytime I'm at a red light or when I park my car. Feels like the car wants to stall but it doesn't. Feels like my engine is 'sputtering'. The check engine light comes on once in a while but I think that's from my O2 sensor, b/c I have a CAI. Not too worried about that.
I did some research on here and checked all my vacuum tubes and turns out there's no leak, plus I even went ahead and changed the PCV valve. I also changed the fuel filter. Still no help. I remember there was a link somewhere in these threads relating to oscillating rpms and I went through it, no help.
So I figured it might be:
I need new plugs and wires
New fuel pump
Clean the fuel injectors
I decided to come on here and ask you guys b/c some of you guys really know ur shit . Plus I don't want to do all the above b/c I don't have that kid of $ to toss around. So any help would be great.
BTW: It's a 95 Integra SE
-Joe
Old 06-03-2006, 10:04 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Semi-Oscillating RPM
http://www.automotiveforums.com/vbul...archid=1552161
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 06-03-2006, 08:09 PM
Originally Posted by superbluecivicsi
bad link
Old 06-04-2006, 12:13 AM
WReX WReX is offline
Originally Posted by hungarian_boss
bad link
i think he's trying to say search the forums...not sure tho
anyway, if you have a CEL do you know for sure its an O2? if not get it read ASAP and that will be a big step in your diagnosis
sounds like a bad/clogged IAC valve (idle air control valve) its located on the back of your intake mani. behind the throttle body, remove it, get some brakleen or parts solvent and clean it out, it that doesn't change anything, maybe it needs replacement
and fyi, a CAI will not throw O2 codes, most of the time only a bad O2 sensor will throw a O2 code
26 PSI anyone?
Old 06-04-2006, 02:35 AM
nitebeest nitebeest is offline
Pull the spark plugs and see if there is any abnormal coloration. That'll let you know if something in your engine is running wrong (too lean, too rich, too hot, etc, etc). If that's the case you'll prob have to replace the plugs anyways. Could be the fuel pump. I've heard of cars going down the road and choking out and stalling because of bad fuel pumps. Not a good thing. I'd definately say pull the code on the CEL next time it comes up though. And fuel injector cleaner is only a couple of bucks a bottle... get some... it might help and it's not that expensive.
Old 06-04-2006, 10:05 PM
LoJo LoJo is offline
i'm gonna say its one of your O2 sensors my car did the same thing it even did stall at times but since i've replaced my entire exhaust it hasn't happend since
Old 06-04-2006, 11:58 PM
AF - Advisor
http://www.automotiveforums.com/vbul...archid=1554010
