Old 06-02-2006, 06:59 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
What do I do with these?
I just got some speakers for my project car. When I opened the pair that is going in the dash, Infiniti Reference, a pair of capacitors in a bag fell out. They are axial caps rated at 50 volts and 100µF. The manual doesn't even mention these.
Does anyone know what I'm supposed to do with them?
Old 06-02-2006, 08:17 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: What do I do with these?
there high pass filters for the tweeters. removes freqnecys less then 200hz usually. put them on the positive wire when you wire in the tweets
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 06-02-2006, 08:41 PM
Polygon's Avatar
The Red Baron
Ah, that makes sense, thanks!
Old 06-02-2006, 09:15 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Should be a higher number than 200hz for a high pass to tweets...
Old 06-02-2006, 10:46 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Are they component speakers or, bi-axial etc. If there comps then the crossover would clean up the signal to the tweets and the bi-axial speakers have the "bass blocker" already wired into the tweeter so there is no use for these. Not sure why they would put them in there ive never seen them from infinity, but ive gotten some strange shit from certain companies.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 06-03-2006, 09:26 PM
Polygon's Avatar
The Red Baron
I believe they are component speakers, at least they are according to Infinity's website. They are the Infinity Reference 3012cf.
Old 06-04-2006, 08:19 AM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Poly, a componet speaker has the Mids and Highs seperated, a co-ax has them togather on the same frame.
Cross over point is dependant on impeadance and capasticance as well as inductance. capasitors are used for high pass, inductors for low pass.
