Old 06-02-2006, 06:53 PM
tcrager tcrager is offline
98 Voyager dash not working
I have tried everything. Cleaned the battery terminals, removed the memory fuse under the hood. But still no gauges are not working Transmission location and mileage not displayed. And also the ABS light is on. Any help would be appreciated. Is it possible that the body control module is bad. It did this the other day and after I removed the battery cable it came back on.
Also the interior light when you open the door hasnt worked in almost a year. Also I have checked all the fuses
Old 06-02-2006, 07:38 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 98 Voyager dash not working
If by "it came back on" you mean your gauges worked then yes, the BCM could be out to lunch. Also, run a search through the threads and find the posts that talk about bad solder joints on the instrument cluster and flacky BCMs. It appears to be more common than you might think. Keep in touch.
Old 06-02-2006, 08:34 PM
Yes it did come back on but is back off now after 2 day. Could you tell me where the bcm is located
Old 06-02-2006, 08:59 PM
vipergg vipergg is offline
Try going under the hood in the fuse center and pull the IOD fuse for 2 mintes then reinsert , see if that will liven up the dash , if not then you might have some questionable solder joints on the instrument cluster .
Old 06-02-2006, 10:54 PM
webbee webbee is offline
Originally Posted by RIP
... bad solder joints on the instrument cluster and flacky BCMs. It appears to be more common than you might think. Keep in touch.
Someone posted these instructions on fixing the solder issue on the dash pc board. I don't have the forum link, sorry.
http://www.ingriddijkers.com/CaravanPics.html
Old 06-03-2006, 02:02 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
The BCM is on the back side of the Junction Block fuse and relay center left of the steering column at the bottom of the dash.
Old 06-03-2006, 04:28 PM
bradvabeach bradvabeach is offline
Here's something easy to try. I had dash gauges and lights going off intermittently on my 98 Caravan. It turned out to be that my wife's key had been cut from the wrong blank. The tip-off was that you could make lights come on and off by wiggling the key while the car was running. Worth a try.
Brad
Old 06-03-2006, 06:50 PM
wafrederick wafrederick is offline
Banned
The BCM is toast and you can get one from the dealer only and it has to be programed with Chrysler's factory scan tool,DRB III or a Vetronix scan tool.All that is being progamed is the vin burned in and the mailaige.
Old 06-04-2006, 02:15 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Tough to argue with experience but, I have seen people on this forum get BCMs from junkyards and various websites. Just have to make dam sure you get an exact part # match because there could be several for a given year and each will function differently in some way.
Here's a little gee wiz info: http://www.g35frenzy.com/downloads/2004/04_service_manual/K/bcs.pdf#search='Body%20control%20module'
Looks like you'll have to type it manually.
Old 06-19-2006, 12:51 AM
meezy09 meezy09 is offline
Send a message via AIM to meezy09
if u hold trip and reset buttons on dash display it should give a code in the dash...but im not sure if the no display in dash will make that possiable...but its a way to diag. dash cluster problems. hold for appx 10 to 12 seconds before letting go.
