Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-02-2006, 06:05 PM
DaveNBonne DaveNBonne is offline
Lightbulb 94 Bonneville dashboard problems
The tachmeter, oil pressure gage, voltage meter, coolant meter along with the gas gage doesn't work. It stopped all of a sudden. The only thing that works is my speedometer. What is causing this to happen, and what can I do to resolve this situation.
Old 06-08-2006, 06:11 AM
GTRider0 GTRider0 is offline
Send a message via AIM to GTRider0 Send a message via Yahoo to GTRider0
Re: 94 Bonneville dashboard problems
i do believe that all of the stuff that stopped working were electricial and the only reason your spedo works is becasue it is drivin by a cable i do believe im not 100% sure
Old 06-08-2006, 12:05 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Check your fuses, I believe your guages are all controlled through the same fuse. The speedo is electronic also, but it's on a different fuse circuit.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-09-2006, 10:17 AM
Mark C. 413 Mark C. 413 is offline
I had the same thing happen to my 94 SSE two weeks ago. Had to replace the whole instrument panel(cluster), found one on ebay for 20 bucks. Found out that there is a processor located on the circuit board mounted on the instrument panel goes bad. Easy to change, just takes a little patience.
