Old 06-02-2006, 05:29 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Tachometer's dead.
The car runs now, but my tach needle doesn't even move from-0 rpms when I rev or it idles. It's got a rough idle because there's no muffler but it should be moving altleast when I rev it up.
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 06-02-2006, 06:06 PM
NRFDBeliever NRFDBeliever is offline
Re: Tachometer's dead.
First and most obvious would be to check the wires and the fuse. I'm not 100% certain, but the tach on my camaro has a wire that runs through the guages fuse.
Do you have a distributor with the coil in the cap, or is it external like a MSD Blaster?
Old 06-02-2006, 08:07 PM
Dyno247365's Avatar
the coil is seperate and there's a wire that goes between the cap and the coil, I think...the Ignition coil right? I have an idea then. The wire my be loose.
Old 06-03-2006, 01:27 AM
With a seperate ignition coil you may have to use a different type of setup for your tach. a stock tach hooks into a wire plug on the bottom side of the distributor cap that runs to the coil for it's signal. I haven't looked at them in a long time, but there's some different types of senders that can hook up with an external coil. On my car I installed an MSD 6AL ignition box and that has a tachometer plug in it. I really don't remember where I saw the other types, but I'm sure there's cheaper ones out there.
Old 06-03-2006, 01:47 AM
Dyno247365's Avatar
What's bothering me was that the tach was working a year ago, before I changed the cap and rotor/plugs/wires. I'm wondering why it stopped working now.
Maybe it is the fuse, where can I find the tachometer's fuse? I'm having the car inspected soon so either I fix it or they'll fix it. Either way, I'd like to know what's causing the failure.
Old 06-03-2006, 08:03 AM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
if it was a blown fuse, other gauges would quit also. i dont know much about how the distributor gets its signal. but i would check there. is the oil pressure gauge thats on the tach work?? also when the key is in off the tach should be at 1000 rpms ( or around there) when you turn the key on does the tach needle fall to 0?
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 06-04-2006, 04:33 PM
Dyno247365's Avatar
I left my car running for a few minutes, and all of a sudden my Tach and oil pressure gauges are working perfectly. Umm, I didn't do anything to the gauges. I didn't even find the fuses yet.
Old 06-04-2006, 09:33 PM
goldz28's Avatar
goldz28 goldz28 is offline
Same thing happened to my 90 Iroc I had. It was the instrument cluster was bad and had to get a new one. My speedo did not work tho. It would however work 1 out of 100 times. So it was intermittent. Good luck Quick
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 06-05-2006, 04:43 PM
As he said, it could very well be your instrument cluster. If the problem is intermittent it's the worst type to try and troubleshoot. Chances are that you have a short somewhere or something is going bad (like the instrument cluster) but hasn't completely gone out yet.
In closing, I'd like to 2nd the "Good luck."
