Go Back   Automotive Forums Car Chat > Buick > Regal
Old 06-02-2006, 03:32 PM
[email protected] photopm@gmail.com is offline
1996 keyless entry programming
I have a 1996 Buick Regal and I need to program two new remotes.
I see about three different methods referenced on this site, but no one says which process works.
Can someone help?
Old 06-03-2006, 07:43 PM
Re: 1996 keyless entry programming
I found the answer myself. It worked.
In the trunk next to the antenna, there is a wire that is not connected to anything.
Jumper it to ground.
The car locks and trund lock will cycle.
Press the lock button on the remote.
The door locks will cycle, but the trunk will not.
If you have another remote, press the lock button.
The door locks will cycle, the trunk will not.
Remove the jumper.
The remotes are programmed.
[email protected]
Old 06-22-2006, 11:34 PM
cuda010 cuda010 is offline
where did you find the instructions? I have a 97, the all the instructions I found for mine dont work. thanks for your help.
Old 06-23-2006, 08:10 AM
I found them on the internet in a post by a GM Maint shop Manager.
