Old 06-02-2006, 09:48 AM
FTheMan FTheMan is offline
Two questions.
One. Would it be cheaper or easier to buy an LS6 engine or just upgrade an LS1 to an LS6?
Two. What is so wrong with Fram oil filters?
Old 06-02-2006, 10:56 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Two questions.
an ls6 has a different block, heads, and intake manifold so u can't totaly upgrade an ls1 to an ls6. so im gonna say cheaper to buy the ls6. although some 01-02 fbodies slipped out of the factory with ls6 blocks.
with fram oil filters, i think they break apart over time and don't filter as well as other similarly priced filters. i use wix personaly
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 06-02-2006, 12:32 PM
malletslinger's Avatar
malletslinger malletslinger is offline
Re: Two questions.
when did this news come out about the fram filters?!?
I thought fram was suposed to be a good filter! What about proline, are they ok?
Old 06-02-2006, 12:58 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Re: Two questions.
Nope, fram sucks.
Old 06-02-2006, 04:12 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: Two questions.
Okay, here's the run down on Fram's oil filters guys and gals.
Oil Filters come basically in three qualities. Very good, with excellent filtration; normal; and really incredibly bad. This last category, really incredibly bad, should obviously be avoided. Accordingly, never use a Fram, Pennzoil, Penske, Castrol, or Quaker State oil filter in any motor you like. All of these filters are made by Fram. The filter element itself is a normal paper element, and probably no better or worse than anyone else's paper element. However, the end caps on the filter element are made of cardboard in these filters. There are numerous stories of these cardboard end caps getting saturated with oil and coming apart, putting little cardboard fragments directly into the oil flow into your engine bearings. As they say in Ghost Busters, this "would be bad." Personally, I don't consider cardboard a suitable material for my engine internals.
This is one reason why i always recommend Purolator oil filters, which you can find at any Advance Discount auto parts store. Purolator makes filters in three qualities, standard, premium, and Pure One. Purolator states that their premium filters capture 97.8% @ 30 microns and 85.2% @ 20 microns. These numbers are typical of a normal paper element oil filter. The Purolator Pure One filters capture 99.8% @ 30 microns and 99.2% @ 20 microns. This means the Premium filter is letting through eleven times as many 30 micron particles as the Pure One, and eighteen times as many 20 micron particles. Clearly, the Pure One filter is doing a considerably better job of cleaning the oil than the premium filter.
The way the Pure One achieves this filtering efficiency is by combining three different types of materials in their filter: paper like everyone else to catch the big stuff, and cellulose and fiberglass fibers to fill in the "large" holes in the paper with their much finer fibers. Filters like this are now made by Purolator, Hastings (marketed as AMS), and Champion (marketed as Mobil 1 and Bosch). Accordingly, the best oil filters are the Purolator Pure One, Mobil-1, AMSOil, and Bosch. If you use one of these filters with one of the commercial synthetic oils listed above, you have the best protection money can buy.
Champion says the Bosch is a 15 micron filter, and the Mobil-1 is a 10 micron filter but gives no efficiency numbers. Fram makes a new filter, the X2, which they claim is in this category, but I'm skeptical of all things Fram. In particular, Fram officials seem to claim that all Fram filters have a rating of 10 microns, which calls into serious question how they measure their paper filters, and also why one would pay three times as much for their advanced filters given that they have the same rating as their basic filters. SAE tests would tend to indicate that the Purolator has a slight advantage in filtering over the other filters named here. The important thing is, all of these filters have performance at 30 microns which is far superior to a paper only filter, and all of these filters have performance at 20 microns which is also far superior to a paper filter. So, bottom line, the filters stated in the last paragraph will clean your oil far better than Frams paper-only filter.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 06-02-2006, 04:51 PM
Re: Two questions.
That's a damn good explaination. Thanks.
Old 06-02-2006, 06:08 PM
Re: Two questions.
I agree, thank you.
Old 06-02-2006, 06:09 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: Two questions.
Since when has blind eyed been a moderator?
Old 06-02-2006, 06:42 PM
blindeyed's Avatar
eBay aDdict™
Re: Two questions.
- Jason
Old 06-02-2006, 07:23 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Two questions.
Remember the mod apps?. He made a damn good one but TS asked me what I thought and said he was mod material. So there he is. Firebird mod for now but soon to be global I am sure. BTW, I agree thats a damn good post and as a matter of fact, I never really payed close attention to oil filters. I usually just grab one off the shelf and hope it works good enough but now I am going to be sticking with purolator after reading that.
Speaking of good posts, the Firebird and Camaro forums are soon going to have merged sub forums and I had mentioned a few weeks back to a few different members that I would love to make some fact sticky's and common techinical issue's for each gen F-body but unfortunetly I am no specialist in each gen. Most of my knowledge is in 4th gens and I know a fair share about third gens cause they share alot of common parts with 4th gens and I have worked on a few but I think it would be great if everyone could get involved and throw some idea's up or like a group effort of sharing facts . Such as maybe a few of you guys with Third gens could write something up and I know we don't have many first and second gen owners but I am sure Korn or Earlsfat could share some light as well as Kasey with some V6 stuff and Mr.Luos with LS1 facts. Anyway, let me know what you guys think.
John
PS- I am sorry to hijack the thread but Blind pretty much had it covered.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 06-02-2006, 07:39 PM
ZL1power69's Avatar
GM S-Series Mod
Re: Two questions.
i used fram for 1 day cause i was in a bind. changed the next day with a wix.
Low 11 sec sleeper
My Cardomain
Old 06-03-2006, 08:25 AM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
Re: Two questions.
One question, do you get on hell of a sales commission?
J/k
Good read
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 06-03-2006, 12:18 PM
Re: Two questions.
Alright. I'd like to know more about the LS6. What is the displacment? What kind of power did it have in the F-bodies it came in? Anywhere near the power of the Vette one of was it drasticly detuned?
Old 06-03-2006, 03:09 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Re: Two questions.
That's a good question. I've never heard of LS6 Camaros or Firebirds before this thread. The LS6 was 346ci like the LS1 but the early Z06s came with 385hp and then later on was rated at 405hp. The torque's very similar to the hp numbers
I think GMHTP magazine dynoed the LS6 at 415hp while it was in a Camaro. If it came like that factory I can't remember...but I remember they were testing different mods on it and started out stock.
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 06-03-2006, 03:14 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Two questions.
Are you looking to buy a new LS6???
What exactly are you planning here?
What exact info are you looking for??
Sorry, I could write a post about 3 pages long if not given specifics. And I really don't want to do that.
The blocks are slightly different. But will NOT affect power output.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
