Old 06-02-2006, 09:44 AM
1986TBIRDV8 1986TBIRDV8 is offline
Is this possible?
Okay, here's my situation.
2 Kicker's. One of them is a SVC at 4 ohms. The other is a DVC at 4 ohms.
I have a 2 channel amp and I want to bridge these two subs. My amp CAN handle the impedence. My question is this. How do I go about wiring these subs so I can do this?
Old 06-02-2006, 10:41 AM
JunkTitleGolf's Avatar
JunkTitleGolf JunkTitleGolf is offline
Re: Is this possible?
What amp do you have. I am thinking that the impedence would be at 3 ohms. But don't quote me on that.
1995 VW Golf
Cold Air Intake
Cat delete
Full straight pipe exhaust
4 gauge big 3
Pioneer head unit
Power Acoustik Amp
Cerwin Vega Vmax sub
Old 06-02-2006, 10:47 AM
It's a 1200 watt 2 channel Power Acoustik Gothic Series. 2 ohm stable.
Old 06-02-2006, 11:51 AM
You can wire them at 2 ohms go to http://www.crutchfieldadvisor.com/le...ng.html?subs=2 and look at 2 subs / Single Voice Coil - 4 ohms Option #1 this will put you at 2 ohms. Also you would be using the DVC sub as a single voice coil to do this.
1995 VW Golf
Cold Air Intake
Cat delete
4 gauge big 3
Pioneer head unit
Power Acoustik Amp
Old 06-02-2006, 11:17 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Someones gonna blow there shit up doing that. I cant remember the exact equation for sub wiring but. And its not as simple as wiring everything as single subs, then you have 3 seperate 4 ohm vc, in parallel your going to have an ohm rating of 1.3ohms, in series it will 12ohms. 1 ohm will be to low and 12ohms will give shitty power.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
