Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 06-02-2006, 12:25 AM
SigmaProjects's Avatar
SigmaProjects SigmaProjects is offline
Send a message via AIM to SigmaProjects
CO2 spray?
I was thinking about the cooling sprays that some people do with NO2. Do you think there could be any gains from spraying CO2 to cool off the radiator, fuel lines, around the intake pipe, or the ambient heat in the engine bay or anything else? Since CO2 tanks are cheap and fillups aren't that pricey either. Any thoughts, has been tried already, doesn't work well?
RAs, the last of the RWD Celicas... http://truestreets.com/ now out of BETA
Old 06-02-2006, 06:29 PM
91 Celica St 91 Celica St is offline
AF - Advisor
Re: CO2 spray?
meh i wouldnt wast my money, youll se better/bigger gains from water/alc injecton
Old 06-03-2006, 02:24 AM
Re: CO2 spray?
even on a N/A car? I'm really interested in the use of a water/alc injector. How you would use it? Injection into the intake? Spraying down the radiator? Killing some of the ambient air in the engine bay?
Old 06-03-2006, 10:56 AM
blakscorpion21's Avatar
blakscorpion21 blakscorpion21 is offline
Re: CO2 spray?
its been done before there is a company called cryo2 that makes a system. in cool weather there will be little to no gains and decent gains on a hot drag strip. really it is desighned for cars that are high power and are having trouble keeping cool. on a stock or even mildly modified car i wouldnt bother.
Old 06-03-2006, 11:46 AM
Re: CO2 spray?
i see.
Old 06-03-2006, 02:13 PM
AF - Advisor
Re: CO2 spray?
not necessarily, the use in low hp cars is astonishing too, it helps keep ambient temps down witch in turn lets you run leaner and add more timing w out the fear of DT
alot of people DONT like hte concept of mixing alc nad water and dumping it into their engine, plus there seems to be a little problem w the injectors cuz alcohol likes to eat up plastic and rubbermaterials and can eat away rubber fuel lines and eat the injectors/o rings up
Old 06-04-2006, 11:49 AM
Re: CO2 spray?
I reallly wouldn't want that to happen, especially on a newer motor... what about running straight water or something else the isn't as corosive?
Old 06-04-2006, 10:42 PM
AF - Advisor
Re: CO2 spray?
meh, id just stick w water/alc inection, or go metanol
Old 06-05-2006, 01:59 AM
Re: CO2 spray?
but the corrosion you were talking about?
