Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-01-2006, 09:14 PM
ice745 ice745 is offline
AF -Advisor
Wiper Arm Removal.
I have 94 Camry LE.
I want to remove my wiper arms because the paint is coming off of them, and I want to repaint them before they rust. I read the service manual about removal, and it says "Remove the 2 nuts, remove 2 wiper arms", I removed the two nuts no problem, but the wiper arms don't want to be removed. I tried pulling by hand, claw hammer, screw driver, pliers, and my last resort was to give Magneto a call, but he can't seem to get them off either. I sprayed the bolt that they are on with silicone to try to lube it off, but that hasn't worked either. I'm out of ideas. Has anyone removed them before or knows how to actually get them off?
Thanks
Smoking is bad... especially blue smoke!
Fill the oil and check the gas, please.
Old 06-01-2006, 10:48 PM
AF -Advisor
Re: Wiper Arm Removal.
It looks like I need to use a gear puller. I'll pick a cheap one up and see how I do.
Old 06-02-2006, 12:24 PM
DFBonnett DFBonnett is offline
I used a battery terminal puller on the wife's '93. Backed off the retaining bolt a couple of turns, squeezed the jaws closed with my fingers while cranking down on the puller. Once it popped it came off easily.
FWIW
YMMV
Old 06-02-2006, 06:48 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
DFbonnett beat me to it. I did the same thing, used a battery terminal puller on my 94. Incidently, I had my wiper arms powder coated. It's been about 4 years and they still look great.
Mike
Old 06-03-2006, 06:43 PM
AF -Advisor
Thanks :-D
Now I'm just wondering, how do you put them back on safely, to avoid damaging the shaft and the wiper link. Since they are so hard to get off, I'm sure they will be hard to put back on. Should I tap it on with a socket covering the shaft, or will tightening the bolt force them back on without stripping threads?
Old 06-03-2006, 08:15 PM
Just slip them on and tighten the bolts to 14 ft/lbs.
Old 06-09-2006, 02:23 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Remember to mark where the wipers sit on the windshield before you remove them (use tape, grease pencil, etc). Then lift them up into service position and remove the nut. Then you can usually pull them off using a gentle rocking motion. Some arms will be stuck though, necessitating a puller. When reinstalling, make sure you clean the holes and the shafts of any lubricant you may have sprayed on there. I've seen a few armholes get split from being cranked down onto a greased pivot shaft. Realign the arm with the marks on the windshield and tighten down to the torque specified. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
