Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-01-2006, 05:48 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
A few link questions
I'm going to be ordering dsm link next week probably and I have a few questions before I do so.
I'm I correct in thinking that when you send in your ecu they ask you what injectors you are running and they will put in a chip that defults to the settings for that particular size or injectors? And also when you hook up a laptop it asks you what size injectors and puts in a base tune for that size? And lastly can I tell them I'm running 450s and when I get it back just plug it(the ecu) in and go and everything will be ok or do I need to have a laptop before it will work right?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 06-01-2006, 08:08 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: A few link questions
There are a whole slew of default values you need to supply them with. Injector size, CAS inversion or not, idle rpm and other rpms, etc. There is a list on the ordering page of thier site. All of these values can later be changed with the laptop, but these are the figures it will default to when the ECU loses power. It makes sense to at least have the global set right so you can drive the car to a laptop, if you don't have a dedicated laptop for the car. Running on 450 settings with 950 injectors for example will cause a lot of trouble, not the least of which is possible cylinder wall/piston ring damage due to bore wash. With all of the defaults set right, the ECU will run out of the box, no need to connect with the laptop. I always do as a general rule though, not worth taking a risk.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-01-2006, 08:12 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Yes, they will default the chip to the global and deadtime according to your injectors.
The laptop doesn't ask for your injector size. You can do some math with the injector size you have and get the global adjustment % they ask for, it's really easy, and defined in the user manual. Dead time adjustments are also easy, but require a laptop so you can read and adjust the values.
The problem with telling them you want it programmed for 450's is that once you get bigger injectors you will be able to easily adjust for the new injectors, but your default will be wrong. So if you're battery dies or your ECU loses power for whatever reason, the ecu will default back to 450s and you're new injectors will flow WAY too much, and cause problems. I would get them defaulted for whatever you plan on running, and then making the adjustment for your 450s once you can.
DSMLink doesn't NEED a laptop to run at first, but the tune will be very choppy, and like very unstable.
If you don't understand anything just lemme know.
now - 2000 civic
soon - 2002 is300
Old 06-01-2006, 09:06 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Yup they are correct, when i ordered my dsmlink i said what i wanted but when the order was sent and 1 day later i got a 1g head i needed to tell them to invert cas and they did for me WHEEEEEEW. They are awsome and answered all my questions for me when i had them call me. They would not give me there # which i understand why. Camellia is awsome from dsmlink!!!!
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 06-01-2006, 10:07 PM
AF - Advisor
DSMlink customer support/service is in a class of it's own. Nothing else in the realm of DSM specific vendors can compare, IMO.
Kevin Jewer
Old 06-02-2006, 12:17 AM
blk_srt's Avatar
Well the thing is I want to run 1000cc injectors in the future but you know how it goes plans change and I might find a good deal on 950s or something and get those instead so I'm not positive what I'm going to end up running. Think I should wait untill I get the injectors or know forsure what I'll be running and do it all at once or link now?
Mods:
Old 06-02-2006, 12:34 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
You could get link now and just have them set the injectors for lets say a pair of like 660's or something. That way if you're running either the 450s or the 950s/1000s and you lose power, you'll at least be able to limp it around without causing a whole lot of damage, if any at all. Just a thought.
95 Talon TSI AWD
97 Eclipse GST
Old 06-02-2006, 01:01 AM
blk_srt's Avatar
thats an idea. Now the question is will my mom let me borrow her laptop to set it. How hard is it to change injector sizing? I'm good with numbers but havent had much expernce tuning and with fuel trims and such
Mods:
Old 06-02-2006, 06:22 AM
AF - Advisor
950s and 1000s are so similar I'm not sure I'd worry too much about it. Well, it's the difference between 75 and 79 lbs/min, but my point is there isn't much over the 75 lb x67 turbos until you get into the real big stuff, and neither injector will work.
You could adjust for injector size faster than the laptop will boot up. Old injector divided by new injector, minus one. Set that value for global, and go with the typical dead time value for the injectors you run. That will get you in the ballpark. Weeks or months could then be spent tuning in trims and fixing everything that is messing them up on you How much further you go is up to you.
One thing I think I would recomend for someone that doesn't plan to datalog often is setting the knock CEL to come on at something lower than the stock value of 5 degrees. 2 or 3. This way you know if you are getting any decent knock without having to log it.
Kevin Jewer
Old 06-02-2006, 11:32 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I have a question... what is dead time?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-02-2006, 06:42 PM
gstclips gstclips is offline
Send a message via AIM to gstclips
ok so if you disconnect your baterry, it sets it back to that default? thats kinda shitty...I just got my eprom in the mail today. I will most likely always have my laptop in my car, because I dont use it for anything now anyways. can you save the information when you tune it and then you just have to reload it or what?
thats one downfall of link for sure, memoryloss
THE OFFICIAL AF PIMP! - love EclipseRST[Banned]
1997 Gs-t Eclipse
6 bolt + other toys
Currently 295whp
Old 06-02-2006, 11:09 PM
yes you can save the tune and just load it on the eprom in a few seconds. They are working on a memory unit for the 2gs
now - 2000 civic
soon - 2002 is300
Old 06-03-2006, 01:33 AM
AF - Advisor
An injector coil takes a certain amount of time to actually open the injector after the ECU energizes it. Larger injectors tend to react slower. So we add more time to the "dead time" or saturation time as it's sometimes called, to compensate. It's called dead time because it's time the ECU "thinks" the injector is open, but it's not. So lets say the total open time commanded by the ECU is 500 milliseconds, and the dead time is 100 milliseconds. The injector is actually only open for 400. Also, battery voltage affects dead time, and the ECU compensates automatically.
This is a big part of how we can run huge injectors and still get stock like idle and good fuel trims on both cruise and idle
Kevin Jewer
