Old 06-01-2006, 04:51 PM
rackjabbit rackjabbit is offline
ECM Help
Hi, I am new to this forum and already need help. I recently purchased a 1989 Metro LSI with 165k and I want to run a diagnostic. When I follow the dirctions in the Haynes manual and put a fuse into the diagonsis terminal and turn the key nothing happens, no engine check light or message. I am getting about 35mpg on a five speed so I am thinking that something probably needs adusting or repair. Put in new plugs, but nothing else. I would appreciate so helpful comments. Thank you.
Jack
Old 06-02-2006, 12:00 AM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Re: ECM Help
Does the CEL ever come on?
If not, I would suspect the light bulb in the instrument cluster is burned out.
If it does come on at some time during driving, then I haven't a clue.
DoctorBill
Old 06-02-2006, 09:09 AM
Re: ECM Help
No, the CEL has never appeared. DoctorBill, thank you for the suggestion. I will pursue it this weekend. Regards,
Jack
Old 06-02-2006, 09:52 AM
idmetro idmetro is offline
Re: ECM Help
Welcome to the forum; you've probably already read this series of posts but in case you haven't it will give you some ideas of things to check.
http://www.automotiveforums.com/vbul...d.php?t=563910
