| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Engine Removal
When I'm taking the engine out of my 92 eclipse, can I unbult the flywheel from the pressure plate, and leave both of them just hang on the shaft while I remove the engine, or do I have to remove them both with the engine while they are attached? Thanks
Re: Engine Removal
umm...why would you need to take off the tranney to pull the engine...ive pulled several awd and fwd..and never had to take off the tranney...just remove the xfer case and drive shaft...and cvjoints
Jesse
Its a Dsm thing... <img src="http://www.dsmtuners.com/gallery/data/500/44010Pcdv0154-thumb.jpg"> |
Re: Engine Removal
I'm not taking off the tranny thats why I asked about removing the engine from it. Theres very little clearance to pull out the engine, I was curious to see how the flywheel which is bolted to the engine if I;m correct, comes out with it.
Re: Engine Removal
Fly wheel is inside the tranny, on the engine side. If you wanted to remove the fly wheel you would have to take the tranny off. Just pull the sucker out with the tranny attached. There isn't very much room but you just have to fenangle it out of there.
1991 GSX 2.3 Stroker |
