Old 06-01-2006, 12:58 PM
jt5 jt5 is offline
Throttle body diameter?
Does anyone know the throttle body daiameter for a 91 RT/TT?
I bought one of theose aftermarket Y-pipes and it came with a straight 3" coupler. That didnt work so well, so I'm going to buy a reducer coupler and didn't want to take the Y-pipe completely off again to measure the throttle body.
Thanks for any help.
Old 06-01-2006, 03:32 PM
Igovert500's Avatar
blue + red light magnet
Re: Throttle body diameter?
I think it's 60mm but I'm not 100% positive, so hopefully somebody can confirm that.
So where did you get your y-pipe, I'm hoping not ebay. Does the lip have a bead on it? Otherwise it will probably blow off alot under boost.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 06-01-2006, 05:33 PM
Stealthee's Avatar
Stealthee Stealthee is online now
Your worst nightmare
It is a 60mm opening. The outside edge is something like 2.5".
Old 06-02-2006, 01:29 PM
jt5 jt5 is offline
Thanks for the replies. Yes, it was off Ebay and it does have a lip. Seems odd that it does because it only needs it to conform to the stock gasket and there's NO way this pipe will fit with the stock gasket in place.
Old 06-02-2006, 02:22 PM
Igovert500's Avatar
it needs it, because without it, once you start boosting, it will pop right off, you will hear a bang as it hits the bottom of your hood, and your car will die. It's a pretty common occurance.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 06-02-2006, 05:13 PM
Stealthee's Avatar
Haha I did something like that once. My stock intake started falling apart at the joint. I thought I had it fixed, went to the track, launched kept the gas pedal buried as I did a 1-2 shift and BAM, cars struggling. I chugged down the track to a whoping 44 seconds at 22 mph.
