Old 06-01-2006, 11:00 AM
taser1984 taser1984 is offline
Send a message via AIM to taser1984
2000 LeSabre noise in trunk area
In my dad's 2000 LeSabre there is a regular pumping-type noise that comes from the back of the car. It runs for a few seconds every few minutes. What the heck is this, specifically? (It sounds a lot like an air pump but this car does not have air suspension.)
Old 06-01-2006, 03:04 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 2000 LeSabre noise in trunk area
Just a guess, but if it has a rear radio antenna, does it go all the way down when you turn off the ignition and open the door?
Old 06-01-2006, 03:07 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: 2000 LeSabre noise in trunk area
Probably the auto leveling system pump, may have a leak in the system so it runs excessively.
Old 06-02-2006, 09:38 AM
That would seem obvious, but as I said this car does not have self-leveling suspension. Plus the air pump for those is traditionally under the hood, not toward the back.
And the antenna thing would seem obvious, except there isn't one on 2000 up LeSabres (or, rather, it's built into the back glass and doesn't move). It doesn't just run when the car starts or shuts off the way an antenna would, it's at regular intervals throughout the running time.
Old 06-02-2006, 09:54 AM
HotZ28's Avatar
AF Moderator Elite
Actually, I think the air pump is under the rear of the car on 97 up models. Just wondering if this was purchased second hand and the original owner replaced the struts with non-air struts?
Old 06-02-2006, 12:02 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
On my 97 the pump for the air struts is in the right rear. How do you know it doesn't have air struts?
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 06-02-2006, 12:04 PM
stuzman stuzman is offline
I have a 2000 Buick LeSabre and it does have an auto-leveling system for the rear. The air compressor is located under the rear towards the right side. As HotZ says, maybe the previous owner has removed the air shocks and the compressor is continuously running. If everything is intact, then you may have a problem as MaxWedge says. The compressor on my car runs a few seconds after it's started and then shuts off.
Old 06-02-2006, 01:28 PM
A990 racer
AIR pump is in the r/s trunk area.
