Old 06-01-2006, 01:47 AM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Dragging front left wheel?
Hey guys, long story short me and my friend did a bunch of tests to my car today, tried to find that buggerish coolant leak etc. Anyways when we had it on a jack, tires in the air obviously, i put it into Neutral and span the front two tires, the right one spun like butter, the left one on the other hand took a lot more force.. When u did get it spinning it stops 1/2 second later like its catching. I put it into drive and let it idle and spin the tires; again the right one was spinning smoothly no problems, the left one was at a STOP sometimes, u had to push it then it kinda got going but not even close to as fast as the right one.. plus when i revved it a tad it started rumbling @ like 50km/h as if the left side was all catching and off balance..
First thought is maybe the brakes on that wheel are adjusted to tightly from last brake job or w/e? The caliper could be rubbing on the rotor and slowing it down..? When the wheel is spinning it sounds like a slight fffffft, like ur rubbing ur hand across a desk; could just be normal tho..
Or could be from a little bit ago when i hit a patch of ice and hit a pole on the PASSENGER side of the car, guy who did my alignment said "the DRIVER side wheel bearing has a bit of play, but is good for now keep and eye on it" Could the wheel bearing be bad now and causing this? It sounds pretty probable about the wheel bearing to me but would it really make the wheel not spin that smoothly? I know is it isnt proper and is prolly ruining my gas milage,tire wear, brakes if thats the case.. and a bunch of other crap
Any suggestions would be great, any tests I could make sure before getting work done? Thanks a lot!
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 06-02-2006, 08:45 AM
Re: Dragging front left wheel?
Anyone have any info to help me out, it could be rather dangerous.. Thanks
Old 06-02-2006, 10:26 AM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
You don't have a Limited Slip Differential... it does that...
If the wheel bearing were bad you would take it out on the road and feel a vibrations coming from the car (not necessarily the wheel) and hear a rubbing noise from one of the bearings.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 06-02-2006, 12:16 PM
I can feel vibrations pretty bad over like 115km/h on the highway. And also when it was jacked up at like 45km/h it was vibrating horribly, felt like it was coming from the left side also, the right one was spinning like butter. Even in neutral if u spin it manually the right one span like butter and the left one had way more resistance, it felt like its dragging and when u did get it spinning it stopped almost right away, the right one was easy to get spinning and span for a few seconds after freely. In theory it wudnt be differential because in neutral there is no power going to the transmission.
So does this mean u think it is or isnt the wheel bearing then?
Old 06-02-2006, 12:44 PM
mwolvin mwolvin is offline
Only one way to find out for sure. Wheel bearings are not hard to get to. . .
Old 06-03-2006, 11:54 AM
Indeed. Pull that puppy off and see how well it spins. If its gone bad, replace it. The job's not hard at all unless you got a stubborn one like me and I had to go to a machine shop. But even that's only $20 and some gas extra. So, yeah, go nuts.
Old 06-04-2006, 12:29 AM
Hoe exactly do I get it out, to I have to take the hub off? Tap it with a rubber hammer? Easy instructions plz
Old 06-04-2006, 05:50 AM
Here's a hint...you can't re-pack the bearings in these cars.
Old 06-04-2006, 07:47 PM
Sarcasm? Or do I need a whole new one if I take it out?
Old 06-04-2006, 11:54 PM
wcamaddox wcamaddox is offline
take off wheel, remove brake caliper and rotor,take off big nut on cv axle, three bolts should hold on the bearing remove those and the dust shield should also come off remove bearing its one piece with the wheel studs etc install is opposite
Old 06-08-2006, 10:37 PM
Dunno if im confident enough to take my brakes off yet, I could get a buddy's dad to do it for me though. What also came to mind today is my ABS light has been on for months, would the ABS be kinda locking it up on the one side? I notice when i brake easily i feel an uneasy experience like when ur rotor is "warped", think it could be ABS/sensor on left side locking/slowing it down? Or would it be locking both wheels? Thnx
Old 06-09-2006, 11:54 AM
Brakes are easy. I can have an axle changed out in 20-30 minutes with hand tools. It's two bolts. You may need a large c-clamp to compress the piston slightly to remove it. Just make sure you loosen the cap to the brake resovoir first.
The abs system only releases brake pressure-- it will not cause drag on one side unless the sensor is bent and rubbing.
Slow brake pulsing under light pressure is usually caused by tire wear and will go away at your next tire change. Rotating tires will sometimes help. Really fast pulsing is your ABS coming on.
Old 06-09-2006, 01:45 PM
formulaross formulaross is offline
Cold - Very possible that a worn or somewhat loose wheel bearing is not holding the wheel perfectly upright and is letting the wheel assembly lean slightly, in which case it can contact the brake pads and give the symptoms you describe. On the other hand, a dragging brake caliper can do the exact same thing as well. Only cure is to replace parts - new wheel bearing or rebuild/rebuilt caliper assembly. Dangerous to drive in the current condition? Not really.
Old 06-12-2006, 07:27 AM
not dangerous to drive in that condition? let me tell you a story. my friends wife didnt tell him she had a problem with her car till after the wheel bearing seized while driving down the highway sheared all of the wheel studs of the bearing and sent the wheel hopping down the road. anything that has to do with the running and especially stopping of a car is SERIOUS!
Old 06-12-2006, 11:46 AM
Thanks you guys, good posts. I phoned my local TireCraft, (Good honest guys) and asked em a bunch of questions about it. I told him everything and he said it might be the wheel bearing or the brakes, most likely the bearing. He also suggested it could be the slip differential which someone said, but it doesent sound right if im in neutral spinning the wheel, and its only the left one that drags. Im bringing it in Wednesday and there gonna look at that and my coolant leak for free. Replacing the bearing is a bit pricy but whatever it needs to be done, im probably gonna change my brake pads/rotors soon after too so everything runs smooth.
