Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-31-2006, 09:08 PM
ClutchMaster3087 ClutchMaster3087 is offline
valve replacement
Hey, I need some help. I've never had to replace my valves before, but I bought some stock replacements and don't know where the hell to start at. If anyone has pictures of the process that would be greatly appreciated, because I can't find any.
Old 05-31-2006, 09:17 PM
Killa's Avatar
Killa Killa is offline
Re: valve replacement
You mean valve cover gasket ?? it really easy job, take out all the plug wire, unbolt all the bolt, take out the valve cover, remove all the old gasket, from the valve and engine, put some rvt silicont ( spell ) around the engine , and place the gasket over it, then the valve cover, retight all the bolt with right torge. put all the spark plug wire. turn on the engine and check for leak, you should feel more power after you replace the valve cover gasket. by the way change all the spark plug gasket ( those 4 ring thing, it should come with the gasket kit ). you done.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 05-31-2006, 09:59 PM
ned032002's Avatar
ned032002 ned032002 is offline
NOOOO he means valves there Killer, look at the pic he has.
Old 05-31-2006, 10:31 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
haha way to go killer...
Old 05-31-2006, 10:34 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
are you asking on a" HOW TO" to relace valves? I know you can make a specal spring compressor off Dsmtuner tech articals. I've never botherd paying much attention becasue I havn't had my head fail... yet....<knock on wood>
Old 05-31-2006, 10:43 PM
Killa's Avatar
LOL first time I read, the pix wasnt their. now it is .
GM FOR LIFE !!
95 camaro lt1
Old 05-31-2006, 10:48 PM
ned032002's Avatar
Killer, you don't have to lie to make friends alright.
Old 05-31-2006, 11:39 PM
Killa's Avatar
I swear I dint saw those pix first time I was reading it. I know what valve is, and valve cover is, if those pix is appear in the first place, I just leave this topic alone, but it dint saw it , they why I ask him about valve cover.
GM FOR LIFE !!
95 camaro lt1
Old 05-31-2006, 11:40 PM
Killa's Avatar
by the way, you can edit your message any time you want too.
GM FOR LIFE !!
95 camaro lt1
Old 06-01-2006, 02:43 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Why do you're valves need to be replaced? Depending on the situation i may change the install. If you bent the valves badly you may need some new guides. If you bought oversived valves the seats need to be cut or new seats may be needed. You are probably better off taking it to a machinr shop and having them install the valves.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 06-01-2006, 10:47 AM
ned032002's Avatar
I was just messing with ya Killer.
Old 06-01-2006, 11:27 AM
Killa's Avatar
LOL
GM FOR LIFE !!
95 camaro lt1
