Old 05-31-2006, 08:46 PM
Kidlex01 Kidlex01 is offline
Small rust spots...HELP
2001 GA SE
i have a couple small spots of rust on my car and im wondering how i go about removing them and protecting those spots from re rusting again, and what i should use to remove the rust and protect it afterwards.
Old 05-31-2006, 08:49 PM
maxwedge maxwedge is offline
A990 racer
Re: Small rust spots...HELP
Work done at a body shop, unless you have the skill and proper equipmemt a permanent repair is unlikely.
Old 05-31-2006, 08:58 PM
well ive done alot of autobody work and a small rust spot like the ones on my car cant be that hard to take off. what would be the best thing to use to remove them then protect it.
Old 06-01-2006, 06:20 AM
GTP Dad GTP Dad is offline
Pontiac Guy
The best thing would be to remove all traces of the rust by either sanding or cutting out the effected areas. Once you have them cut out spray them with a rust inhibiter that is available commercially. Actually rustoleum paint works well. Then rough it up and use filler. Sand, clean and repaint.
