Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 05-31-2006, 07:00 PM
rgs63's Avatar
rgs63 rgs63 is offline
Hard starting Sierra
Hey Guys!
My 2000 GMC Sierra 5.3L is hard to start. It's got about 68,000 miles and it doesn't seem to matter if the engines hot or cold, it has to crank over for a few seconds before it will start, sometimes i'll have to try it more than once.
Otherwise it runs great. Have tried disconnecting vacuum line from the fuel pressure regulator to see if there was any fuel in the line, but nothing. Any help would be greatly appreciated!!
Thanks
Old 05-31-2006, 07:27 PM
2000CAYukon 2000CAYukon is offline
Re: Hard starting Sierra
Originally Posted by rgs63
Hey Guys!
Thanks
It would be good to hook a fuel pressure gauge up to the fuel rail to see what your starting pressure is. Should be around 60 PSI to start up.
//2000CAYukon
Old 06-01-2006, 10:49 AM
swensonb71 swensonb71 is offline
Send a message via Yahoo to swensonb71
I agree, I have had that same problem before with my '96 and it was the fuel pump pressure being weak after double checking it with a fuel pressure tester. mine was at 40 psi instead of the 60 plus psi that it needs at start-up.
Old 06-01-2006, 01:33 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
They are known to have fuel pressure regulators go bad.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 06-03-2006, 12:10 PM
rgs63's Avatar
Hey Guys,
I didn't have access to a fuel pressure tester, so I took a chance and bought a new fuel pressure regulator. But, I'm still having the same problem. Any other suggestions?
Thanks
Old 06-04-2006, 12:58 PM
horse482's Avatar
AF -Advisor
Have you checked for any stored trouble codes? As far as the fuel system you are going to have to do as told above and get a fuel pressure guage and see what pressure when the truck is running. When was the last time you changed your fuel filter?
NO 4 N JUNK
Old 06-05-2006, 07:07 PM
rgs63's Avatar
No, haven't checked for trouble codes. I changed the fuel filter back in august of '04, at about 55,000 miles. I guess I'll have to take it to a garage and have them run some tests.
Thanks
