Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 05-31-2006, 07:35 PM
miwise miwise is offline
One more question about fuel economy
Hello again,
I back because I forgot to ask one question about this Ford Econoline Van.
I have a 1990 ford econoline custom van. Does anyone know what type of mileage these things get? Mine has a 351 efi mated to a e4od tranny and is getting about 10 mpg. I just don't know if I should expect better. I thought it should be getting close to 15. Thanks!
Old 06-01-2006, 10:33 AM
gbic1 gbic1 is offline
Re: One more question about fuel economy
I have heard of people getting that milage but dont count on it. I dont have a van but do have two Ford trucks and one Bronco. Bronco has 5.0 overdrive and gets 10/13. Both trucks are 5.8 and get 9/14.5 and 9/15.8 and I have had these for many years with constant results.
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
Old 06-01-2006, 08:22 PM
I am glad to hear that it is normal and not just engine problems! Thanks for the info!
Old 06-01-2006, 08:24 PM
BTW, should I tow my boat in third gear? My manual says to leave overdrive engaged, but others tell me to force it to stay in third gear. Which should I do? It doesn't have enough power when going uphill. (mostly when towing boat, but engine bogs even without boat)
Old 06-01-2006, 08:30 PM
One more thing, sorry :-). . .Is compression of 120 psi on all cylinders bad, good, or indifferent? Could that be an indication of my low oil pressure problem? When I stop, sometimes (especially right after turning vehicle off then starting back up) I hear a grinding noise from the engine. What could cause this? Some have said that it could be main bearings, but it doesn't do it all the time. It doesn't do it if the engine isn't warmed up.
