Old 05-31-2006, 06:22 PM
tabaker tabaker is offline
resistor in temp sensor
Has anyone experimented with putting a resistor in parallel with the temp sensor to trick the computer into thinking the car is warmer than it really is so the computer turns the fans on earlier. This may cause other problems if the engine is using this temperature to control other devices. I didn't want to put a manual switch in and was thinking of giving this a try.
'93 trans am'
Thanks...
Old 05-31-2006, 10:27 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: resistor in temp sensor
it would probably be safer to reprogram the computer to tell it to turn the fans on earlier.. not only is it safer, you can use that comp to drop/raise your redline..change shiftpoints..etc etc.
i wouldnt mess with the sensor directly.. but who knows! it might work. :]
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 05-31-2006, 10:29 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Don't.
A fan switch would be your best bet.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 06-01-2006, 06:22 AM
Can I reprogram the computer on a 93. I'm not positive but I though you could only do that on the newer years.
I suppose the switch is the safest way to go. I just hate mounting/drilling in the interior.
Thanks all...
Old 06-01-2006, 05:54 PM
Mr. Luos's Avatar
Firebird Guy
Ashtray.
Stock'ish'
Old 06-02-2006, 02:38 AM
hahah! nice.
yeah im sure you can reprogram it..i could be wrong @_@; if i am, correct me plz.. but yeah.. hardwire works too..make sure you get a lower temp thermostat too or its no use..
Car:
285's in the back
all else = STOCK.
Old 06-02-2006, 07:33 AM
FormulaForce FormulaForce is offline
You can get a Hypertech programmer for about $300 new, or maybe e-bay has a used one. As mentioned above, it allows you to program many things including the fan turn-on temperature. I have one i used to re-program the rear gear ratio (4.10) so the speedometer reads right, and raised the top speed limiter. They could not be easier to use. The resistor idea makes sense though, in theory you could measure the cold and hot sensor resistance difference with a meter and put an equal-range potentiometer (variable resistor, couple bucks from radio shack) in series with the sensor, that way you could adjust the exact point at which the fans come on. In parallel, resistance is divided between the two, and the fans probably won't come on. Worth a try for a couple dollars and splicing one wire.
Old 06-02-2006, 09:23 PM
yup yup, i got the hypertech programmer. i brought my RPM redline down for now... (till i do a full on fluid flush )
Car:
285's in the back
all else = STOCK.
Old 06-02-2006, 09:49 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Originally Posted by Mr. Luos
Don't.
agreed!(see, I agree with Lous from time to time )
The 93 cars are not programmable w/o a PROM. They still use the "chip" like fords.
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
