Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 05-31-2006, 05:57 PM
bluelogic bluelogic is offline
Replacing rear power window motor/regulator
Hi,
My mother has a 2002 Ford Focus SE that has a rear window that has to be held up with tape. The window motor used to make noise and no longer does. I need to know do I need to replace the motor and the regulator? In addition how hard is this to do? I replaced window motors on a Chev. Astro Van and that was a pain. Had to drill out the rivets to get access.
Thanks
Bluelogic
Old 05-31-2006, 06:03 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Replacing rear power window motor/regulator
Pretty sure they should be just held in with screws (once you get the door panel off) I know replacing them on my moms van was the same way as your astro (had to drill out the rivets)
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
