Go Back   Automotive Forums Car Chat > Eagle > Vision
Old 05-31-2006, 03:17 PM
JudasPriestScream JudasPriestScream is offline
96 Vision TSI - AC/Heat Console gone Haywire
Hi all,
This is my first post here and I hope I can get some feedback on this crazy problem.
My AC/Heat console started going nuts on me, turning on by itself, not shutting off, and not turning on - for both heat and AC. NOW it doesn't work at all and just blows heat off the engine out of it. Also, if I fiddle with the temp and fan knobs, my speedometer, gas, and RPM needles bug out then go dead.
The dealer wanted to replace the console and ignition switch and it was almost 1000$. I said forget it and I am shopping around a bit more.
Anyone have any ideas on this at all?
Thank you,
JPS
Old 05-28-2007, 01:33 PM
Crokie Crokie is offline
Re: 96 Vision TSI - AC/Heat Console gone Haywire
Hi,
Just wondering if you every got your problem with the heating solved. I seem to be having the same problem. Let me know.
Crokie
Life may not be the party we hoped for...
but while we're here, we might as well dance!
Old 06-07-2007, 11:40 PM
Solomon Cloud Solomon Cloud is offline
Send a message via AIM to Solomon Cloud
sounds like you have/had a short to ground. most likely a power wire that for the ac/heat has been damaged and started contacting a piece of metal in the car. When the bare wire shorts itself to ground it'll cause it to turn on/off and eventually burn itself and other components out.
Also and this is a theory the short had fried part of the computer that controls the climate control and blew something so it no longer turns on the heater or ac compressor, but only the blower motor.
unless you know how to test wiring and have some wiring diagrams and a multimeter handy I dont know what to say.... checking fuses would be the best step as if the resistance in the wire had gone above the amperage for it the fuse should blow for the components to protect them from being destroyed.
it could be simple enough as a bare wire and some blown fuses, or bad enough as fried electrical components that will need to be replaced.... you just gotta start digging into it....... or live with it and roll yo windows down when its hot.
Old 06-11-2008, 10:15 PM
93metro 93metro is offline
i had the same problem while driving to florida (great time to have full heat coming out). what i found that the controls were very hot!! i had to take out the piece metal over the top of the A/c / heater controls. this fixed my prob. I think that it needs more airflow to keep it cool.
hope this helps yours
