Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-31-2006, 03:01 PM
ArSargE7 ArSargE7 is offline
Intake manifold gasket
I have read that many folks in this forum have Intake manifold gasket (IMG) problems. I have had the gaskets replaced 3 times. First was under warranty. Last two have been in the 200 – 300 dollar price range. The last time was in Nov 05, the truck is starting to act up like the gasket is failing again.
Does anyone know what is causing these failures and is there a permanent fix?
Gasket replacement is getting to be expensive!
Old 05-31-2006, 03:13 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Intake manifold gasket
incorrect torque. Isuzu has changed it 3 times. I think it is 11ft lbs now.
Check over at www.planetisuzoo.com. I know it was recently posted there.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 05-31-2006, 07:25 PM
I went to planetisuzoo.com and did a search in forums on intake manifold and torque. Got 45 hits and they all said 13 ft lbs.
Old 06-01-2006, 02:31 AM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
just checked isuzu service manual it is 13 ft lbs
Old 06-01-2006, 07:39 PM
johnsm johnsm is offline
I just wrote that I torqued my bolts on my IMG to 11 ft lbs because they just cracked and year ago I installed them at 14 ft lbs. Someone wrote a response to me that torque wrenchs lose accuracy in the lower settings and I should buy a smaller one. Sounds good to me.
Here is a question. Can we make our own gaskets? My thought is that Isuzu made the gaskets out of plastic and plated top and bottom with steel to 1) make and airtight seal 2) to expand and contract with heat so as not to crack the aluminum manifolds.
Can you make a gasket out of solid 3/16 plate steel, aluminum, copper or heat resistance composite material (plastic or hard rubber)?
If you made an aluminum gasket with a paper or liquid gasket on top and bottom would this not be a better solution. The expansion and contraction rate would be the same as the manifold.
John
Old 06-02-2006, 09:29 PM
Tom01Rodeo Tom01Rodeo is offline
You probably should be torqueing with an inch/pound torque wrench. 11 ft/pds = 132 in/pnds
Old 06-12-2006, 05:46 AM
Decipha Decipha is offline
i believe they have copper gaskets, im not too sure about intake gaskets but i have some friends that build race engines with copper gaskets on the heads... im looking for a copper intake gasket myself, but the vehicle im regarding is a 97 pontiac grand prix 3800 series
sry mods i'll try 2 b good
Old 06-12-2006, 09:18 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
For a grand prix you can probably find copper gaskets but not for the rodeo. Can only get the thick plastic ones isuzu uses, not so much aftermarket for isuzu parts.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 06-14-2006, 08:37 AM
Can you just buy a sheet of copper the right thickness. I could probably machine it to the right demensions
